高分求助:想做一个gcc mips交叉编译器,在make buildroot时遇到如下问题,请教如何解决,最好还能指导下如何作出这个交叉编译器,谢谢!
Alen.yang   2007-10-4 13:23 楼主
dirk@dirk-laptop:~/buildroot$ make menuconfig
make CC="/usr/bin/gcc" -C package/config conf mconf
make[1]: Entering directory `/home/dirk/buildroot/package/config'
/usr/bin/gcc -DCURSES_LOC="" -DLOCALE -g -O2  -c lxdialog/checklist.c -o lxdialog/checklist.o
In file included from lxdialog/checklist.c:24:
lxdialog/dialog.h:32:20: error: curses.h: No such file or directory
lxdialog/dialog.h:97: error: expected specifier-qualifier-list before ‘chtype’
lxdialog/dialog.h:187: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:194: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:196: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:197: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:198: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:199: error: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:201: error: expected ‘)’ before ‘*’ token
lxdialog/checklist.c:31: error: expected ‘)’ before ‘*’ token
lxdialog/checklist.c:59: error: expected ‘)’ before ‘*’ token
lxdialog/checklist.c:95: error: expected ‘)’ before ‘*’ token
lxdialog/checklist.c: In function ‘dialog_checklist’:
lxdialog/checklist.c:116: error: ‘WINDOW’ undeclared (first use in this function)
lxdialog/checklist.c:116: error: (Each undeclared identifier is reported only once
lxdialog/checklist.c:116: error: for each function it appears in.)
lxdialog/checklist.c:116: error: ‘dialog’ undeclared (first use in this function)
lxdialog/checklist.c:116: error: ‘list’ undeclared (first use in this function)
lxdialog/checklist.c:129: error: ‘stdscr’ undeclared (first use in this function)
lxdialog/checklist.c:130: error: ‘KEY_MAX’ undeclared (first use in this function)
lxdialog/checklist.c:137: error: ‘COLS’ undeclared (first use in this function)
lxdialog/checklist.c:138: error: ‘LINES’ undeclared (first use in this function)
lxdialog/checklist.c:143: error: ‘TRUE’ undeclared (first use in this function)
lxdialog/checklist.c:146: error: ‘struct dialog_color’ has no member named ‘atr’
lxdialog/checklist.c:147: error: ‘struct dialog_color’ has no member named ‘atr’
lxdialog/checklist.c:151: error: ‘struct dialog_color’ has no member named ‘atr’
lxdialog/checklist.c:156: error: ‘struct dialog_color’ has no member named ‘atr’
lxdialog/checklist.c:171: error: ‘struct dialog_color’ has no member named ‘atr’
lxdialog/checklist.c:210: error: ‘KEY_UP’ undeclared (first use in this function)
lxdialog/checklist.c:210: error: ‘KEY_DOWN’ undeclared (first use in this function)
lxdialog/checklist.c:220: error: ‘FALSE’ undeclared (first use in this function)
lxdialog/checklist.c:297: error: ‘KEY_LEFT’ undeclared (first use in this function)
lxdialog/checklist.c:298: error: ‘KEY_RIGHT’ undeclared (first use in this function)
lxdialog/checklist.c:312: error: ‘KEY_RESIZE’ undeclared (first use in this function)
make[1]: *** [lxdialog/checklist.o] Error 1
make[1]: Leaving directory `/home/dirk/buildroot/package/config'
make: *** [package/config/mconf] Error 2
dirk@dirk-laptop:~/buildroot$ sudo make menuconfig
回复评论 (2)
呵呵,题目有问题。什么叫做 做一个 gcc mips交叉编译器?
看你的结果,有文件都找不到。
建议你最好先看一下makefile怎么写。编译结果显示相对没有makefile重要,如果能写出makefile,那么离编译通过就不远了。
点赞  2007-10-4 18:13
备份下后,make mrproper
再make menuconfig
点赞  2007-10-6 09:45
    写回复
