我想将一个PPC 2002的源程序移植为EVC4标准SDK,以便在普通的wince系统上运行。
我用EVC4打开工程文件,并在标准SDK环境下编译不通过,缺少Aygshell.h.
我找到PPC 2002 SDK里的Aygshell.h、Aygshell.lib,加到工程,编译通过了,但无法在模拟器上运行调试,提示如下:
An application targeting a Standard SDK for Windows CE .NET and built for the X86 CPU cannot be run on the Emulator device. In order to run this application on any CPU other than the Emulator, you will have to install an SDK that is compatible with the Standard SDK for Windows CE .NET, then target a shadow platform pertaining to that SDK.
是否我的移植思路有问题?或者需要Aygshell.dll?还是其它什么原因?
请达人回复,多谢
