请教关于C8051F040+CP2200的问题 总是发现自动协商失败
wangjian801213   2008-8-25 16:21 楼主
我自己划的板子由C8051F040和CP2200组成 使用PM34-1006变压器进行输入网络信号  发现程序初始化没有问题 但是CP2200时钟无法完成自动协商
我曾经买了块C8051F020的网络开发板 使用Silabs成功使用了UDP通信 所以我把CP2201的四根网络输入线 直接接上了自己划板子的CP2200 还是没有反应(因为这样连接可能有问题)
所以还是期待变压器的正确连接 虽然排除不了本身程序的问题 但是直觉还是信号没有进来  我把CP2200的底层驱动帖出来 希望大家帮帮忙!
unsigned char CP2200_HW_Reset(void)
   char SFRPAGE_SAVE = SFRPAGE;
   data unsigned char temp_char;
   CP2200_RST_Low();//将cp2200的复位脚置低
   wait_ms(20);
   // Step 1: Wait for the reset pin to rise.
   CP2200_RST_High();//将cp2200的复位脚置高
   // Step 2 + 3: Wait for oscillator and self initializaion to complete
   wait_ms(5000);
   /* wait for OSC Init interrupt */
   while(INT_PIN)
   // INT0 is not reading 0xFF;
   wait_ms(1000);
   while(((temp_char & 0x30) != 0x30) || (temp_char == 0xFF))
       temp_char = INT0RD;
   // Verify communication
   if(RXHASHH != 0x04)
      return MEM_ERROR;
   // Read and write the RAM at 0x7FF in the transmit buffer
   // we can verify the send/rev buffer normal
   RAMADDRH = 0x07;
   RAMADDRL = 0xFF;
   RAMTXDATA = 0x00;
   if(RAMTXDATA != 0x00)
      return MEM_ERROR;
   RAMTXDATA = 0xFF;
   if(RAMTXDATA != 0xFF)
      return MEM_ERROR;
   /* Init has completed */
   // Step 4: Disable Interrupts For Events that will not be monitored
   // Disable All Interrupts except for the packet received interrupt
   INT0EN = 0x03;     //关中断   允许接收缓冲区满和数据包已接收中断
   INT1EN = 0x00;
   // Clear all Interrupt Flags by reading the self-clearing status registers
   temp_char = INT0;
   temp_char = INT1;
   SFRPAGE = SFRPAGE_SAVE;
   debug_ledDn = 1;
   return 0;
unsigned char PHY_Init()
   unsigned char retval = 0;
   unsigned char i = 0;
   // Step 1: Disable the PHY
   PHYCN = 0x00;  //禁止phy
   // Step 2: Enable the PHY with link integrity test and auto-negotiation
   // turned off
   // A. Disable the Transmitter Power Save Option and Configure Options
   TXPWR = 0x80;
   PHYCF = ( SMSQ | JABBER | ADPAUSE | AUTOPOL);//配置phy工作方式         enable auto-negotiate
   // B. Enable the Physical Layer
   PHYCN = PHYEN;//允许phy
   wait_ms(10);
   PHYCN = ( PHYEN | TXEN | RXEN );
   wait_ms(2000);
   // Step 3: Poll the Wake-on-Lan Interrupt
   // A. Clear Interrupt Flags
   temp_char = INT1;//清除中断标志
   // C. Check for a signal
   for(i = 0 ; i < 150; i++)
      wait_ms(10);
      temp_char = INT1RD;
      // If a signal is detected, wait 250 ms, then continue
      if(temp_char & WAKEINT)
         wait_ms(250);
                 debug_ledUp = 0;
         break;
   // Physical Layer Initialization (Section 15.7 of CP220x Datasheet)
   // Step 1: Synchronization procedure implemented above
   // Step 2: Disable the physical layer
   PHYCN = 0x00;
   // Step 3: Configure the desired physical layer options including
   // auto-negotiation and link integrity
   PHYCF = ( SMSQ | LINKINTG | JABBER | AUTONEG | ADPAUSE | AUTOPOL );
   // Step 4: Enable the physcial layer
   // A. Enable the Physical Layer
      PHYCN = PHYEN;
   // B. Wait for the physical layer to power up
      wait_ms(10);
   // C. Enable the Transmitter and Receiver
   // Auto-negotiation begins now
   // Step 5: Wait for auto-negotiation to complete
   // Clear INT1 Interrupt Flags
      temp_char = INT1;
      // Check for autonegotiation fail or complete flag
     for(i = 0; i < 60; i++)
             wait_ms(100);
             temp_char = INT1RD;
         // If Auto-Negotiation Completes/Fails, break
         if(temp_char & (ANCINT | ANFINT))
            break;
      // Mask out all bits except for auto negotiation bits
      temp_char = INT1RD;            //中断状态寄存器1
      temp_char &= (ANCINT | ANFINT);  //0x01 | 0x04 = 0x05           与后仅仅观察自动协商的标志位
      // Check if Auto-Negotiation has FAILED
      if(temp_char & ANFINT)
          {                     //自动协商失败
         // Auto-Negotiation has failed
         retval = LINK_ERROR;
          else if(temp_char == ANCINT)                           // Check if Auto-Negotiation has PASSED
         // Auto-Negotiation has passed
         retval = 0;
          else
   return retval;
回复评论 (4)
小弟先谢过了
点赞  2008-8-26 10:16
点赞  2008-8-30 10:06
自动协商不需要软件参与就可完成。如不能成功,该是硬件有问题。可能是连线错误。
点赞  2008-9-3 22:53
能不能把你的CP2200 的UDP 通讯代码发给我学习学习呢?邮箱283090402@QQ.com
谢谢了
点赞  2008-11-25 10:24
    写回复
