哪个高手帮我看一下,我用的lpc915,为什么开不了机!
zzp2658   2007-8-6 13:25 楼主
源代码如下,在模拟环境上,是可以正常运行的,可是烧到板子上,就开不了机了!
#include
unsigned long  data1;
int bitcnt;
bit Power_flag,Key_flag;
sbit P12=P1^2;
sbit LED =P1^1;
sbit Power=P0^0;
sbit Reset=P1^4;
//定时器初始化
void clock_initial()
    TMOD=0x10;  //采用定时器1,模式1
    TR1=0;
    TH1=0x00;    //初始化定时器1
    TL1=0x00;
//串口发送
/*void putchar(unsigned char rsbuf1)
          TI=0;
         SBUF = rsbuf1;
          while (TI==0) ;
          TI=0;
//ASCII码转换
char ASCIITurn(unsigned char c)
  if (c>=0&&c<=9)
          c=c+0x30;
  else if (c>=0xA&& c<=0xF)
          c=c+0x57;
  return c;
  //   字符串输出
void putstring(char *rsbuf,int b)
  char i=0;
  char b1,b2;
  while(rsbuf)
          if (rsbuf=='\n')
           putchar('\r');
           putchar('\n');
        else if (rsbuf=='%'&&rsbuf[i+1]=='d')
             b1=ASCIITurn(b&(0x0f)); //另一种方式表达
             b2=ASCIITurn((b>>4)&(0x0f));
            putchar(b2);
            putchar(b1);
                        i++;
         else
             putchar(rsbuf);
         i ++;
//时间延迟
delay(unsigned int DelayTime)
while (DelayTime)
DelayTime--;
//输出波形(整个编码波形)
void SentKey(unsigned long data1)
   char BitKey;
    EA=0;
    P12=0;
    delay(2070);
    P12=1;
    delay(1034);   //输出9ms的脉宽
    while(bitcnt)
                BitKey=(data1>>(bitcnt-1))&(0x01);        //取位
               bitcnt--;
               if (BitKey==0)
                           P12=0;
                       delay(128);
                       P12=1;
                       delay(128);        //输出0信号脉宽
               else
                           P12=0;
                        delay(128);
                        P12=1;
                       delay(388);       //输出1信号脉宽
        Key_flag=0;
        delay(65000);
EA=1;
//外部中断服务程序
void exint0_isr(void) interrupt 0 using 0
{  /*unsigned char rsbuf1;*/
    unsigned int timer;
    /*char b1,b2;*/
    bit  temp;
    EA=0;
    TR1=0;
    timer=(TH1*256+TL1);            //读定时器1的值
    TH1=0x00;
    TL1=0x00;
    TR1=1;
    if (timer>1704 && timer<2442)           // "0"信号
        temp=0;
    else if (timer>3769 &&timer<4506)      //"1"信号
        temp=1;
    else if (timer>19906 && timer<29859)   //header信号
        bitcnt=-1;
        data1=0;
                Key_flag=0;
     bitcnt++;
     if (bitcnt>=1&&bitcnt<=32)           //开始接收前32位
         data1=data1|temp;
     if (bitcnt==24)
            /*rsbuf1=data1>>(bitcnt-24)&0xff;
             b1=ASCIITurn(rsbuf1&(0x0f)); //另一种方式表达
             b2=ASCIITurn((rsbuf1>>4)&(0x0f));
            putchar(b2);
            putchar(b1);
             putstring("\n");*/
            Key_flag=1;
     if (bitcnt<32&&bitcnt>0)        //左移
           data1=data1<<1;
        EA=1;
//复位
void ReSet(void)
    Reset=1;
    delay(4608);
    Reset=0;
    delay(2308);
    Reset=1;
//电源控制
void Power_Set(void)
     if (((data1>>8)&0xff)==0x30)
                 if (Power_flag==0)
                        Power=1;
                     delay(4600);
                      ReSet();
                     LED=0;
                    /*delay(5000);
                      LED=1;*/
                    Power_flag=1;  //开电源并且复位
                else
                        LED=1;
                        delay(5600);
                        LED=0;
                    Power=0;
                      Power_flag=0;
        Key_flag=0;
main (void)
   DIVM=1;
    EX0=1;
    EA=1;                        //开中断
    SCON=0x50;         //串口方式1,允许接收
    IT0=1;                     //下降沿触发
    ET1=1;
    BRGCON =0;
    BRGR1=0x02;
    BRGR0=0xF0;          //波特率为4800
    BRGCON =3;
    P0M1=0x00;
    P0M2=0x01;            //P0.0口为推挽
    P1M1=0x00;            //P1.1,P1.4为推挽
    P1M2=0x12;
    clock_initial();
        Power=0;
        Reset=0;
        Power_flag=0;
    /* Reset=0;
        Power=0;
        LED=0;
        delay(46100);   //延时200ms
        LED=1;
        ReSet(); */
   while(1)
    /*if (flag==1)
                 delay(46100);
                 LED=1;
           SentKey(data1);
        flag==0;
       if(Key_flag==1&&((data1>>8)&0xff)==0x30)
              Power_Set();
                delay(6500);
                if (((data1>>8)&0xff)==0x00&&Key_flag==1)
                        SentKey(data1);
                        LED=1;
                delay(6500);
回复评论 (1)
开不了机应该 跟程度没关系,看看你的复位电路有没有问题,,应该 是在P1.5上上拉一个电阻,其它都不用接的。
还有就是跟复位电路有关的寄存器设置看看有没有写错,,
如果还是不行的话,,就把程序分开功能,一块一块烧进去,,,看看具体是哪块出问题了吧。
点赞  2008-6-21 14:31
    写回复
