tornado 2.2 连编译都抛异常
jwzhou2007   2007-11-21 19:14 楼主
刚装上WINDRIVER.TORNADO.V2.2.FOR.POWERPC
什么都没加 只是一个最简单bootable的工程 想用VXSIM仿真一下 结果连编译都过不了 具体异常如下
Exception 0xC0000005: EXCEPTION_ACCESS_VIOLATION
Log file has been generated and saved as:
C:\Tornado2\host\x86-win32\bin\Tornado-Problem-20071121-190459.log
========================================= ( possible first 4 parameters )
0x011C0112          ( 17629184 [0x010D0000], 3, 0, 3423872 [0x00343E80] ...)
LdrInitializeThunk[0x029]          ( 18612224 [0x011C0000], 17629184 [0x010D0000], 3, 0 ...)
LdrShutdownThread[0x0ED]          ( 39369432 [0x0258BAD8], 11036336 [0x00A866B0], 584 [0x00000248], 584 [0x00000248] ...)
ExitThread[0x03E]          ( 0, 11035808 [0x00A864A0], 72286080 [0x044EFF80], 1598130088 [0x5F4187A8] ...)
endthreadex[0x034]          ( 0, 2288012 [0x0022E98C], 0, 1598129920 [0x5F418700] ...)
CStringList::CStringList[0x020]         list_s.cpp line   45.0         ( 0, 1, 2088886098 [0x7C81DF52], 11036336 [0x00A866B0] ...)
CControlBar::PreTranslateMessage[0x044]         barcore.cpp line  361.108         ( 2288012 [0x0022E98C], 2088886098 [0x7C81DF52], 1598049764 [0x5F404DE4], 11036000 [0x00A86560] ...)
endthreadex[0x0A9]          ( 11036000 [0x00A86560], 2088886098 [0x7C81DF52], 1598049764 [0x5F404DE4], 11036000 [0x00A86560] ...)
GetModuleFileNameA[0x01B4]          ( 2009113409 [0x77C0A341], 11036000 [0x00A86560], 0, 200 [0x000000C8] ...)
stdout:
stderr:
stdin:
Registers:
eax=00000001 ebx=011C0014 ecx=00000000 edx=00000000
esi=012800DC edi=00000001 ebp=044EFE1C esp=044EFCFC
eip=011C0112 flg=00010202 fs=001B      gs=0023
cs=0023      ds=0023     ss=003B      es=0000
Bytes at cs:eip:
001B:011C0112:  FF 96 68 01 00 00 EB 01 B5 89 83 31 04 00 00 EB
Stack dump at ss:esp:
0023:044EFCFC:
00000000 044EFE30 00343E80 00000000  ....0﨨.?>4.....
1EA38D24 C2202754 E5E9CE28 92336C43  $崳.T' ?伍錍l3?
1DC3011A 60F10713 7BE543A6 26B13BC8  ..?..馺?鍆??
4FB02965 7D320609 1B1444B5 5D54786E  e)癘..2}礑..nxT]
3E87CB77 32822F6C 662642BC 46403CDB  w藝>l/?糂&f?@F
91ED9593 0C05E41B 54A46DD0 20667E67  摃響.?.衜?g~f
3E575C13 9DE87188 58A189CB 74C213B7  .\W>坬铦藟??聇
04D01788 A3BF2D9B C549F843 2C639A7C  ???浚C鳬舼歝,
FE1AC7CC A76F3A13 66F6D5D8 E92A623F  糖.?:oж睁f?b*?
7851589C 5975FDDF C199EFCB 8FDCB7E7  淴Qx啐uY孙櫫绶軓
FD7C71B2 2124A543 98EC1214 4E45582C  瞦|鼵?!..鞓,XEN
112E2751 6EFA3F0A CAA7FD01 2579A3F2  Q'...?鷑.?黍?%
7C930570 FFFFFFFF 7C93056D 76F312DE  p.搢????m.搢?髒
00240000 00000000 01A48668 044EFDF0  ..$.....h啢.瘕N.
044EFDFC 736590C9 044EFDFC 73659CA3  ?N.蓯es?N.?es
00344208 00000001 7365908C 00000003  .B4.....寪es....
End of Log
回复评论 (6)
这是for ppc吗
点赞  2007-11-21 20:45
没装好吧,可能是安装问题,可以考虑重新装一下。 另外也可能是你自己的Windows不好啊。
这种问题,不是每个人都会碰到的。
点赞  2007-11-22 16:50
bsp包装了?
点赞  2007-12-18 07:59
bsp包装拉的
点赞  2008-1-19 09:29
很明显,提示的信息是x86的寄存器,不是PowerPC 的寄存器,仔细看看一楼 菜鸟曹 的 回复就清楚了
点赞  2008-1-28 21:13
不会,帮顶
点赞  2008-5-1 14:51
    写回复
