Timer事件不响应的问题
lingdukongjian   2007-11-14 11:12 楼主
EVC编的程序,在PDA上运行。API编程,没有用MFC
窗体的Timer事件不响应,可我把窗体隐藏后,却响应了。可能是什么原因呢?会不会是某些地方阻住了?
设置定时器:SetTimer(pass,1,1000 ,NULL);//pass是窗体的句柄
这个窗体句柄我检查过,没问题。断点跟踪,没进入过WM_TIMER的代码内。把窗体隐藏后,进入了。那么应该也不是Timer的ID号的问题。
回复评论 (7)
没有必要再发一个贴子吧
把代码打包,传上来吧。否则没有办法分析的,可以肯定是程序的问题。
点赞  2007-11-14 11:26
试试这个
#include
#include
#include
#include "Commdlg.h"
#define MAX_LOADSTRING 100
// Global Variables:
HINSTANCE hInst;        // current instance
TCHAR szTitle[MAX_LOADSTRING] = {L"Nemochips"};        // The title bar text
TCHAR szWindowClass[MAX_LOADSTRING] = {L"NEMO"};        // The title bar text
static g_bImageDrawn = FALSE;
HMENU hmTrackPopup;
// Foward declarations of functions included in this code module:
ATOM                                MyRegisterClass(HINSTANCE hInstance);
BOOL                                InitInstance(HINSTANCE, int);
LRESULT CALLBACK        WndProc(HWND, UINT, WPARAM, LPARAM);
LRESULT CALLBACK        About(HWND, UINT, WPARAM, LPARAM);
int WINAPI WinMain(HINSTANCE hInstance,HINSTANCE hPrevInstance, LPTSTR lpCmdLine,int nCmdShow)
        // TODO: Place code here.
        MSG msg;
        HACCEL hAccelTable;
        INT a = 0;
        Sleep(5000);
        ATOM tom = MyRegisterClass(hInstance);
        // Perform application initialization:
        if (!InitInstance (hInstance, nCmdShow))
                printf("winmain InitInstance fail !");
                return FALSE;
        CoInitialize(NULL);
        hAccelTable = LoadAccelerators(hInstance, (LPCTSTR)"");
        // Main message loop:
        while (GetMessage(&msg, NULL, 0, 0))
                if (!TranslateAccelerator(msg.hwnd, hAccelTable, &msg))
                        TranslateMessage(&msg);
                        DispatchMessage(&msg);
        return msg.wParam;
        WNDCLASS    wndclass;
        wndclass.style = CS_HREDRAW | CS_VREDRAW;
        wndclass.lpfnWndProc = (WNDPROC)WndProc;
        wndclass.cbClsExtra = 0;
        wndclass.cbWndExtra = 0;
        wndclass.hIcon = NULL;
        wndclass.hInstance = hInstance;
        wndclass.hCursor = NULL;
        wndclass.hbrBackground = (HBRUSH) GetStockObject (WHITE_BRUSH);
        wndclass.lpszMenuName = NULL;
        wndclass.lpszClassName = szWindowClass;
        return RegisterClass (&wndclass);
BOOL InitInstance(HINSTANCE hInstance, int nCmdShow)
        HWND hWnd;
        hInst = hInstance; // Store instance handle in our global variable
        hWnd = CreateWindow(szWindowClass, szTitle, 0,
                0, 0, 320, 240, NULL, NULL, hInstance, NULL);
        if (!hWnd)
                printf("create fail!!!");
                return FALSE;
        ShowWindow(hWnd, nCmdShow);
        UpdateWindow(hWnd);
        SetFocus(hWnd);
        SetTimer(hWnd, TIMER_ID, TIMER_RATE, NULL)
        return TRUE;
//  FUNCTION: WndProc(HWND, unsigned, WORD, LONG)
//  PURPOSE:  Processes messages for the main window.
//  WM_COMMAND        - process the application menu
//  WM_PAINT        - Paint the main window
//  WM_DESTROY        - post a quit message and return
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
        int wmId, wmEvent;
        PAINTSTRUCT ps;
        HDC hdc;
        TCHAR *pszHello = TEXT("NemoPlayer");
        //LoadString(hInst, 111, szHello, MAX_LOADSTRING);
        FILE *fpYUV = NULL;
        switch (message)
                case WM_COMMAND:
                        wmId    = LOWORD(wParam);
                        wmEvent = HIWORD(wParam);
                        // Parse the menu selections:
                        switch (wmId)
                        default:
                                return DefWindowProc(hWnd, message, wParam, lParam);
                        break;
                        case WM_PAINT:
                                hdc = BeginPaint(hWnd, &ps);
                                // TODO: Add any drawing code here...
                                RECT rt;
                                GetClientRect(hWnd, &rt);
                                DrawText(hdc, pszHello, _tcslen(pszHello), &rt, DT_CENTER);
                                EndPaint(hWnd, &ps);
                                break;
                        case WM_DESTROY:
                                PostQuitMessage(0);
                                break;
                        case WM_TIMER:
                                break;
                        default:
   return 0;
点赞  2007-11-14 12:06
我把程序截取了一下,可能有点乱,以下是出问题的窗体的代码:
#include "stdafx.h"
#include
#include "player.h"
#include "try.h"
#include "0005.h"
#define PLAYER 1
#define MAIN 0
//HINSTANCE hInstance= NULL;
unsigned short        usX_Bg_BitMap2;//背景位图在clientarea的位置
unsigned short        usy_Bg_BitMap2;
unsigned short        usWidth_Bg_BitMap2;
unsigned short        usHeight_Bg_BitMap2;
HWND                        g_hwndBTplayer[5];
HWND g_hwndslider[15];
TCHAR        BtplayerClassName[]=TEXT("bt");
TCHAR        SliderClassName[]=TEXT("slider");
//标志位:
static bool playornot=true;
static LPCTSTR lpString;
static LPCTSTR lpStringtemp;
        HWND m_hWnd;
        HWAVEOUT hwo;
        WAVEHDR hdr;
        PBYTE pBufferBits;
        PWAVEFORMATEX pwfx;
        char Lname[30][100];
        char* Ljingdu[30];//此处不正确
        char* Lweidu[30];
        char* Llujing[30];
        char* Lrange[30];
        int hangID;
        DWORD volume;
        unsigned int vol;
        bool autoclose;
        unsigned long second;
        DWORD dwDuration;
        DWORD  dwPlayRate;
HWND                        g_hwndlist;
HWND                        g_hwndpro;
HWND pass;
//HWND passbutton;
LVITEM lvItem;
int mark;
LPTSTR lujing;
//=_T("My Documents\\个人\\peoplepark.wav");//支持汉字路径:OK!!!
LPTSTR pszText=NULL;//Why设为此类型???
extern int formstate;
int i;
int m;
        DWORD dwNumRead;
        DWORD dwNum;
bool paintagain;
LRESULT CALLBACK Dlgplayer(HWND hDlgplayer, UINT message, WPARAM wParam, LPARAM lParam)
        HDC hdc,hdcMem;
        PAINTSTRUCT ps;
        static HINSTANCE hInstance = NULL;
        //存储背景位图的句柄
        static HBITMAP hBitMapBk;
        //background位图的宽度与高度
        static int cxSource,cySource;
        pass=hDlgplayer;
        switch (message)
        case WM_CREATE:
                                BITMAP bitmap;
                                //获取实体句柄
                                hInstance = ((LPCREATESTRUCT)lParam)->hInstance;
                                //获取背景位图句柄
                                unsigned int uiID = (unsigned int)MAKEINTRESOURCE(IDB_BITMAP_BACK_GROUND2);
                                hBitMapBk = LoadBitmap(hInstance,(LPWSTR)uiID);
                                //获取背景位图详细信息
                                GetObject(hBitMapBk,sizeof(BITMAP),&bitmap);
                                cxSource = bitmap.bmWidth;//位图大小最终是窗体大小
                                cySource = bitmap.bmHeight;
                                g_hwndBTplayer[0] = CreateWindow(BtplayerClassName,TEXT(""),
                                                 WS_CHILD|WS_VISIBLE,
                                                 180,45,53,54,
                                                         hDlgplayer,NULL,
                                                         ((LPCREATESTRUCT)lParam)->hInstance,NULL);
                                InitCommonControls();
                                g_hwndlist = CreateWindow(WC_LISTVIEW,TEXT(""),
                                                 WS_CHILD|WS_VISIBLE|LVS_ALIGNTOP|WS_VSCROLL|LVS_EX_FULLROWSELECT|
                             WS_BORDER|LVS_REPORT,
                                                 15,25,160,180,
                                                         hDlgplayer,NULL,
                                ListView_SetExtendedListViewStyle(g_hwndlist, LVS_EX_FULLROWSELECT);
                                LV_COLUMN   lvcol;
                                lvcol.cx   =   158;
                                lvcol.mask   =   LVCF_FMT   |   LVCF_TEXT   |   LVCF_WIDTH;
                                lvcol.fmt   =   LVCFMT_LEFT;
                                lvcol.pszText= _T("景点名称");
                                ListView_InsertColumn(g_hwndlist,0,(const LV_COLUMN FAR*)& lvcol);
                                g_hwndpro = CreateWindow(PROGRESS_CLASS,TEXT(""),
                                                 WS_CHILD|WS_VISIBLE|PBS_SMOOTH|WS_BORDER,
                                                 15,215,160,10,
                                                         hDlgplayer,NULL,
                                PostMessage(g_hwndpro,PBM_SETSTEP,(WPARAM)1,0L);
                                PostMessage(g_hwndpro,PBM_SETPOS,(WPARAM)50,0L);
                                SetFocus(pass);
                                second=0;
                                SetTimer(hDlgplayer,1,1000 ,NULL);
                        break;
                case WM_SIZE:
                                RECT rect_client ;
                                GetClientRect(hDlgplayer,&rect_client);
                                usHeight_Bg_BitMap2 = (unsigned short)rect_client.bottom;
                                usWidth_Bg_BitMap2 = (unsigned short)rect_client.right;
                                usX_Bg_BitMap2 = (unsigned short)rect_client.left;
                                usy_Bg_BitMap2 = (unsigned short)rect_client.top;
                        break;
                case WM_TIMER:
                        switch(wParam)
                case 1:
//                                          MessageBox(pass,_T("ss"),_T("dd"),MB_OK);
                                          second++;
                                          PostMessage(g_hwndpro,PBM_SETPOS,(WPARAM)second,0L);
                                          if(second==dwDuration)
                                                  KillTimer(hDlgplayer,1);
                      break;
                default:
                                          break;
                        break;
                case WM_PAINT:
                            hdc = BeginPaint(hDlgplayer, &ps);
                                //重画机体背景位图
                                hdcMem = CreateCompatibleDC(hdc);
                                SelectObject(hdcMem,hBitMapBk);
                                //SetStretchBltMode(hdc,COLORONCOLOR);
                                StretchBlt(hdc,usX_Bg_BitMap2,usy_Bg_BitMap2,usWidth_Bg_BitMap2,usHeight_Bg_BitMap2,
                                //StretchBlt(hdc,usX_Bg_BitMap,usy_Bg_BitMap,cxSource,cySource,
                                hdcMem,0,0,cxSource,cySource,SRCCOPY);
                                DeleteDC(hdcMem);
                                EndPaint(hDlgplayer, &ps);
                        break;
                case WM_DESTROY:
                        DeleteObject(hBitMapBk);
//                        DeleteObject(hBitMapTB00);
//                        PostQuitMessage(0);
                        break;
        return FALSE;
LRESULT CALLBACK BTPlayerWndProc(HWND hWndbtplayer,UINT message,WPARAM wParam,LPARAM lParam)
        SetFocus(pass);
        return 0;
LRESULT CALLBACK SliderWndProc(HWND hWndslider,UINT message,WPARAM wParam,LPARAM lParam)
        SetFocus(pass);
        return 0;
我试过,把g_hwndBTplayer[0] = CreateWindow(BtplayerClassName,TEXT(""),
                                                 180,45,53,54,
                                                         hDlgplayer,NULL,
这一段去掉之后,timer就可以响应了。应该是这个按钮子窗体的问题。但是不知为什么。
窗体类的注册是这样的:
ATOM MyRegisterClass(HINSTANCE hInstance, LPTSTR szWindowClass)
        WNDCLASS        wc;
    wc.style                        = CS_HREDRAW | CS_VREDRAW;
    wc.lpfnWndProc                = (WNDPROC) WndProc;
    wc.cbClsExtra                = 0;
    wc.cbWndExtra                = 0;
    wc.hInstance                = hInstance;
    wc.hIcon                        = LoadIcon(hInstance, MAKEINTRESOURCE(IDI_MY0005));
    wc.hCursor                        = 0;
    wc.hbrBackground        = (HBRUSH) GetStockObject(WHITE_BRUSH);
    wc.lpszMenuName                = 0;
    wc.lpszClassName        = szWindowClass;
        RegisterClass(&wc);
        wc.hbrBackground        = (HBRUSH) GetStockObject(BLACK_BRUSH);
        wc.lpfnWndProc = (WNDPROC)Dlgmain;
        wc.lpszClassName = ClassNameMain;
        RegisterClass(&wc);
        wc.lpfnWndProc = (WNDPROC)Dlgplayer;
        wc.lpszClassName = ClassNamePlayer;
        RegisterClass(&wc);
        wc.lpfnWndProc = (WNDPROC)Dlgsample;
        wc.lpszClassName = ClassNameSample;
        RegisterClass(&wc);
        //注册按钮窗体
        wc.lpfnWndProc = (WNDPROC)BTWndProc;
        wc.cbWndExtra = sizeof(long);
        wc.hIcon = NULL;
        wc.lpszClassName = BtClassName;
        RegisterClass(&wc);
        //注册出问题的窗体的按钮子窗体:
        wc.lpfnWndProc = (WNDPROC)BTPlayerWndProc;
        wc.hIcon = NULL;
        wc.lpszClassName = BtplayerClassName;
        RegisterClass(&wc);
        //注册slider窗体
        wc.lpfnWndProc = (WNDPROC)SliderWndProc;
        wc.hIcon = NULL;
        wc.lpszClassName = SliderClassName;
        return RegisterClass(&wc);
点赞  2007-11-15 10:33
帮忙看一下怎么回事
点赞  2007-11-15 10:35
The WM_TIMER message is a low-priority message. The GetMessage and PeekMessage functions retrieve this message only when no other higher-priority messages are in the thread's message queue.
g_hwndBTplayer[0]   =   CreateWindow(BtplayerClassName,TEXT( " "),
                  WS_CHILD ¦WS_VISIBLE,
                  180,45,53,54,
  hDlgplayer,NULL,
  ((LPCREATESTRUCT)lParam)-> hInstance,NULL);
我猜可能是你的那个窗口占用太多资源吧。
点赞  2007-11-15 11:20
这样看代码,不容易看出问题的。
楼主最好将自己整个工程打包。呵呵~,我的要求是不是有点太高!源代码可是宝贝。
点赞  2007-11-15 11:32
问题已经解决了
点赞  2007-11-22 12:59
    写回复
