IC卡 45db041芯片和卡座上的8个引脚是如何对应的?
lordice   2007-4-17 12:05 楼主
如题.datasheet上没有IC卡模块对应的引脚.网上也没找到资料.
回复评论 (4)
让卡厂出资料,呵呵...
天知道他用的是什么东西,一个小破存储芯片,不知道用的是哪个的哈...
点赞  2007-4-17 12:16
接触式 的ic卡的管脚是一样的吧,那要看iso7816-1的。
触点朝向您,触点在下方
下一行从左到右为1,2,3,4,上一行从左到右为5,6,7,8
Contact  Designation  Use
C1  Vcc  Power connection through which operating power is supplied to the microprocessor chip in the card
C2  RST  Reset line through which the IFD can signal to the smart card's microprocessor chip to initiate its reset sequence of instructions
C3  CLK  Clock signal line t hrough which a clock signal can be provided to the microprocessor chip. This line controls the operation speed and provides a common framework for data communication between the IFD and the ICC
C4  RFU  Reserved for future use
C5  GND  Ground line providing common electrical ground between the IFD and the ICC
C6  Vpp  Programming power connection used to program EEPROM of first generation ICCs.
C7  I/O  Input/output line that provides a half-duplex communication channel between the reader and the smart card
C8  RFU  Reserved for future use
点赞  2008-2-1 17:56
什么呀
点赞  2008-5-1 19:45
不能上传图片,给个简图吧:
AT45DB041, SI为Pin1
SI   ---|------|--- SO
SCK  ---|      |--- GND
/RET ---|      |--- VCC
/CS  ---|_____ |--- /WP
点赞  2008-5-1 22:53
    写回复
