sql ce安装问题?(新手求助)
xibeifengse   2007-5-14 17:26 楼主
安装不上,错误如下:
sql server tools is compatible only with sql server 2000 service pack 1 and higher.when you install sql server ce server tools on a computer running both iis and sq1 server 2000,ensure the installer for sql server tools corresponds to the version of sql server 2000
该怎样处理,帮帮忙
先谢谢了
回复评论 (4)
好好看看他的帮助,使用sql server ce2.0 + sp2 必须安装sql server 2000 sp4
我安装了ok,而且用evc + ole db + sql ce 2 + sql server 2000 + sp4 + windows 2000 P + sp4
点赞  2007-5-15 16:27
先安装sql server 2000 sp1或更高版本
点赞  2007-5-15 16:29
http://blog.eeworld.net/dotnet_editor/archive/2005/08/19/459033.aspx
点赞  2007-5-15 16:31
mark
点赞  2007-5-15 23:25
    写回复
