请问:我在运行evc的工程时,提示我说sdk 不能运行在emulator device,这是什么原因呀?
csfang   2007-2-8 09:39 楼主
错误为:
an application targeting a Standard SDK for Windows CE.NET and built for the MIPSII_FP CPU cannot be run on the Emulator device.In order to run this application on any CPU other than the Emulator,you will have to install an SDK that is compatible with the Standard SDK for Windows CE.NET,then target a shadow platform pertaining to that SDK.Please see the eVC help documentation for additional details
                      ______
                      |确定|
回复评论 (1)
平台问题,标准平台不支持mips CPU的代码?
点赞  2008-8-29 21:30
    写回复
