To 设备加载的问题
suweibus   2007-7-11 10:44 楼主
本人使用的硬件是Ez-usb fx2系列68013芯片
但是怎么
NTSTATUS
Ezusb_PnPAddDevice(
    IN PDRIVER_OBJECT DriverObject,
    IN PDEVICE_OBJECT PhysicalDeviceObject
Routine Description:
    This routine is called to create a new instance of the device
Arguments:
    DriverObject - pointer to the driver object for this instance of Ezusb
    PhysicalDeviceObject - pointer to a device object created by the bus
Return Value:
    STATUS_SUCCESS if successful,
    STATUS_UNSUCCESSFUL otherwise
   NTSTATUS                ntStatus = STATUS_SUCCESS;
   PDEVICE_OBJECT          fdo = NULL;
   PDEVICE_EXTENSION       pdx;
   WCHAR KernelDeviceNameBuffer[] = L"\\Device\\Ezusb-0";
   UNICODE_STRING KernelDeviceNameUnicode;
   WCHAR UserDeviceLinkBuffer[] = L"\\DosDevices\\Ezusb-0";
   UNICODE_STRING UserDeviceLinkUnicode;
   RtlInitUnicodeString (&KernelDeviceNameUnicode,
                          KernelDeviceNameBuffer);//&KernelDeviceNameUnicode
   Ezusb_KdPrint(("enter Ezusb_PnPAddDevice\n"));
   ntStatus = IoCreateDevice (DriverObject,
                              sizeof (DEVICE_EXTENSION),
                              NULL,
                              FILE_DEVICE_UNKNOWN,
                              0,
                              FALSE,
                              &fdo);
   if (NT_SUCCESS(ntStatus))
      pdx = fdo->DeviceExtension;
          /*RtlInitUnicodeString (&UserDeviceLinkUnicode,
                          UserDeviceLinkBuffer);
      ntStatus = IoCreateSymbolicLink (&UserDeviceLinkUnicode,
                                     &KernelDeviceNameUnicode);
      RtlCopyMemory(pdx->DeviceLinkName,
                  UserDeviceLinkBuffer,
                  sizeof(UserDeviceLinkBuffer));
      fdo->Flags &= ~DO_DEVICE_INITIALIZING;
      fdo->Flags |= DO_DIRECT_IO;
      pdx->PhysicalDeviceObject=PhysicalDeviceObject;
      pdx->StackDeviceObject =
         IoAttachDeviceToDeviceStack(fdo, PhysicalDeviceObject);
      ASSERT (pdx->StackDeviceObject != NULL);
           pdx->usage = 1;
           pdx->OpenHandles++;
           KeInitializeEvent(&pdx->evRemove,
                        NotificationEvent,
                        FALSE);                 }
   Ezusb_KdPrint(("exit Ezusb_PnPAddDevice (%x)\n", ntStatus));
   return ntStatus;
本人只要使用设备描述符L"\\Device\\Ezusb-0";  ,这个些代码,编译出来的驱动程序就不能正常加载,加载到一半时就出问题,代码31,请问高手这是怎么回事,这例程都是一些例子程序中拷贝过来,应该没有问题啊
回复评论 (7)
忘记了,里面还有注释没有去掉,正常如下:
NTSTATUS
Ezusb_PnPAddDevice(
Arguments:
Return Value:
                              NULL,
                              0,
                              FALSE,
                              &fdo);
           pdx->usage = 1;
           pdx->OpenHandles++;
                        NotificationEvent,
                        FALSE);                 }
   return ntStatus;
点赞  2007-7-11 10:45
没有一个人顶,我怎么结贴啊
点赞  2007-7-19 09:41
编译能通过么
点赞  2007-7-19 13:55
终于有人来回话了,晕,可以结贴了,问题我早就解决了,只是没有人回复,没法结贴啊
点赞  2007-7-19 14:08
呵呵!
点赞  2007-7-27 16:48
多几个人来回答一下吧,顶一下就给分的.
点赞  2007-7-27 16:49
用winDbg跟跟...
点赞  2008-1-4 18:57
    写回复
