请问:我在定制windows ce时,我把它的项全选上了,结果编译时有错误?如下
ustc2005   2007-2-6 17:16 楼主
RAM AutoSize: RAM Start=84076000 RAM Size=fdb8a000
Error: Image is too large for current RAM and RAMIMAGE settings
Try setting IMGRAM64=1
Fatal error hit, exiting...
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
Error PB2505: Error executing #(I:\wince_core\first\RelDir\EMULAT~1\)makeimg.exe.
回复评论 (1)
打开你的工程,Platform 菜单,Settings
Build Options 选项卡
选中 Enable Images Larger than 32MB
重新Build操作系统。
点赞  2007-2-6 20:57
    写回复
