EVC窗口切换问题
jhhh999   2007-12-29 09:29 楼主
各位大侠,小弟遇到一个问题,希望各位帮忙解决一下:
我在EVC写了一个窗口切换对话框,但是对话框将系统所有前台文件和后台文件都显示出来,其实我只要显示桌面已经打开对话框就可以了,但是小弟不知怎样过滤这些后台文件。请各位帮忙!!!如下是我写的代码:
// tasklistDlg.cpp : implementation file
#include "stdafx.h"
#include "tasklist.h"
#include "tasklistDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
HWND g_hWndArray[50]; //存所有窗口句柄
CString g_strArray[50]; //存所有窗口标题
int g_iWndCount = 0; //计数器
// CTasklistDlg dialog
CTasklistDlg::CTasklistDlg(CWnd* pParent /*=NULL*/)
        : CDialog(CTasklistDlg::IDD, pParent)
        //{{AFX_DATA_INIT(CTasklistDlg)
                // NOTE: the ClassWizard will add member initialization here
        //}}AFX_DATA_INIT
        // Note that LoadIcon does not require a subsequent DestroyIcon in Win32
        m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CTasklistDlg::DoDataExchange(CDataExchange* pDX)
        CDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(CTasklistDlg)
                // NOTE: the ClassWizard will add DDX and DDV calls here
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CTasklistDlg, CDialog)
        //{{AFX_MSG_MAP(CTasklistDlg)
        ON_BN_CLICKED(IDC_BTNACTIVE, OnBtnactive)
        ON_BN_CLICKED(IDC_BTNREFRESH, OnBtnrefresh)
        ON_BN_CLICKED(IDC_BTNTERMINATE, OnBtnterminate)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CTasklistDlg message handlers
BOOL CTasklistDlg::OnInitDialog()
        CDialog::OnInitDialog();
        // Set the icon for this dialog.  The framework does this automatically
        //  when the application's main window is not a dialog
        SetIcon(m_hIcon, TRUE);                        // Set big icon
        SetIcon(m_hIcon, FALSE);                // Set small icon
//        CenterWindow(GetDesktopWindow());        // center to the hpc screen
        // TODO: Add extra initialization here
         //设置进程列表框标题
        CListCtrl * pListCtrl = (CListCtrl*)GetDlgItem(IDC_LISTPROCESS);
        CRect rt;
    pListCtrl->GetClientRect(&rt);
        pListCtrl->InsertColumn(0,_T("四路激光名称"), LVCFMT_LEFT, rt.Width() * 0.35);
    pListCtrl->InsertColumn(1,_T("激光标题"), LVCFMT_LEFT, rt.Width() * 0.35);
   pListCtrl->InsertColumn(2, _T("线程数"), LVCFMT_LEFT, rt.Width() * 0.30);
        return TRUE;  // return TRUE  unless you set the focus to a control
DWORD CTasklistDlg::GetTaskListCE(PTASK_LIST pList)
HINSTANCE         hKernel        = NULL;
  HINSTANCE         hProcessSnap   = NULL;
  PROCESSENTRY32 pe32           = {0};
  DWORD          dwTaskCount    = 0;
  //状态toolhelp.dll动态连接库
hKernel = LoadLibrary(_T("toolhelp.dll"));
if (!hKernel) {
          ::MessageBox(NULL, L"Toolhelp.dll加载失败", L"进程列举", MB_OK);
    return 0;
  //创建进程映射
hProcessSnap = (HINSTANCE)CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0);
  //如果失败,就退出
  if (hProcessSnap == (HANDLE)-1)
    return 0;
  dwTaskCount = 0;
  //设置保存进程相关内容的变量的结构大小
  pe32.dwSize = sizeof(PROCESSENTRY32);
  //获取第一个进程,并将此进程信息写入进程结构的变量pe32中
  if (Process32First(hProcessSnap, &pe32)) {
    do {
      LPTSTR pCurChar;
      if(_tcsstr(pe32.szExeFile, L"\\"))
        pCurChar = _tcsrchr(pe32.szExeFile, '\\');
      else
        pCurChar = pe32.szExeFile;
      lstrcpy(pList-> ProcessName, pCurChar);
    pList ->dwProcessId = pe32.th32ProcessID;
      pList ->cntThreads = pe32.cntThreads;
      ++dwTaskCount;   //进程数目加1
      ++pList;         //移到下一个结构内存块
    while (Process32Next(hProcessSnap, &pe32)); //移至下一个进程
  else
    dwTaskCount = 0;    //
  CloseHandle (hProcessSnap);
  return dwTaskCount;
BOOL  CTasklistDlg::EnumWindowsProc(HWND hwnd, DWORD lParam)
DWORD             pid = 0;
  DWORD             i;
  TCHAR             buf[TITLE_SIZE];
  PTASK_LIST_ENUM   te = (PTASK_LIST_ENUM)lParam;
  PTASK_LIST        tlist = te->tlist;
  DWORD             numTasks = te->numtasks;
//          CWnd* pwnd = CWnd::FromHandle(hwnd);//
  // 根据窗口句柄,得到进程标识
  if (!GetWindowThreadProcessId( hwnd, &pid )) {
    return TRUE;
  //查找进程标识和列表中相同的进程标识
  for (i=0; i     if (tlist.dwProcessId == pid) {
//                if(::GetWindowLong(hwnd,GWL_STYLE)&&WS_VISIBLE){//
          if (::IsWindowVisible(hwnd)) {//书本
//                        if(hwnd!=NULL&&pwnd->IsWindowVisible()){//
      tlist.hwnd = hwnd;
      int nCnt = ::GetWindowText( hwnd, buf, TITLE_SIZE );
      buf[nCnt] = '\0';
      if (nCnt) {
        lstrcpy( tlist.WindowTitle, buf );
      break;
  //继续列举窗体
  return TRUE;
CWnd* pWnd = CWnd::FromHandle(hwnd);
if(hwnd!=NULL&&pWnd->IsWindowVisible())
   pWnd->GetWindowText(g_strArray[g_iWndCount]);
   if((!g_strArray[g_iWndCount].IsEmpty())&&(g_strArray[g_iWndCount].CompareNoCase(L"Desktop")!=0))
      g_hWndArray[g_iWndCount]=hwnd;
      g_iWndCount++;
return TRUE;
void CTasklistDlg::GetWindowTitles(PTASK_LIST_ENUM te)
//列举系统所有窗体
  EnumWindows((WNDENUMPROC) EnumWindowsProc, (LPARAM) te );
bool CTasklistDlg::ActivateProcess(PTASK_LIST tlist)
//判断是否存在主窗口,如存在就激活它
  if (tlist->hwnd && tlist->WindowTitle)
        ::SetForegroundWindow(tlist->hwnd);
        ::SetActiveWindow(tlist->hwnd);
    return TRUE;
  else
        return FALSE;
bool CTasklistDlg::KillProcess(PTASK_LIST tlist)
HANDLE            hProcess;
  //如果没有主窗体,则用TerminateProcess终止进程
  if (!tlist->hwnd)
        //根据进程标识,返回进程句柄
    hProcess = OpenProcess( PROCESS_ALL_ACCESS, FALSE, tlist->dwProcessId );
    //成功的话,终止进程
        if (hProcess)
      if (!TerminateProcess( hProcess, 1 ))
        CloseHandle( hProcess );
        return FALSE;
      return TRUE;
        else
          return FALSE;
  //有主窗体,发送主窗口关闭消息,终止线程
  else
    ::PostMessage( tlist->hwnd, WM_CLOSE, 0, 0 );
    return TRUE;
void CTasklistDlg::OnBtnrefresh()
TASK_LIST_ENUM processList; //进程列表信息
        TCHAR numBuf[10]; //存储进程中的线程数
        memset(&g_tlist, 0, sizeof(TASK_LIST) * MAX_TASKS);
        //得到进程列表信息
        DWORD nNumTasks = GetTaskListCE(g_tlist);
        processList.numtasks = nNumTasks;
        processList.tlist = g_tlist;
        //更新进程列表信息,获取主窗口句柄和标题
        GetWindowTitles(&processList);
        //清除列表框所有项目
        pListCtrl->DeleteAllItems();
    memset(&numBuf,0,sizeof(numBuf));
        //向列表框中添加进程相关信息
        for (int i=0;i         {
        //进程exe名,标题名,线程数
      pListCtrl->InsertItem(i,_T("Test"));
          pListCtrl->SetItemText(i,0,processList.tlist.ProcessName);
          pListCtrl->SetItemText(i,1,processList.tlist.WindowTitle);
          _itow(processList.tlist.cntThreads,numBuf,10);
          pListCtrl->SetItemText(i,2,numBuf);
void CTasklistDlg::OnBtnactive()
   POSITION         pos = pListCtrl->GetFirstSelectedItemPosition();
   if (pos)
     int nItemIndex = pListCtrl->GetNextSelectedItem(pos);
         //激活进程
         ActivateProcess(&g_tlist[nItemIndex]);
void CTasklistDlg::OnBtnterminate()
   if (pos)
         //终止进程
         KillProcess(&g_tlist[nItemIndex]);
   //刷新进程列表
   SendMessage(WM_COMMAND, (WPARAM)IDC_BTNREFRESH, 0);
回复评论 (3)
SF
头晕....
这个可以去VC区找答案..
没做过不知道
点赞  2008-1-2 16:06
上面仁兄,您能否说清楚一点,我找很久,都没有找到!!!
点赞  2008-1-7 09:41
呵呵,上面说了,我没做过的...这个我觉的应该有相应的函数吧,而且这些功能上VC区人做的多些.这里太少了..
点赞  2008-1-8 08:59
    写回复
