ccs编译问题error: unrecognized token
cumtliyan   2010-8-24 10:16 楼主
j = *(UNIT_VOL_BASEADDR + wUintIndex );    直流电压遥测
 WriteBYC((wUintIndex + YCPOSITION_DCA1),j); //变化遥测
 Report.DCVol[wUintIndex] = j;
程序老实在这块报错,错误如下
"SVG_interupt.c", line 119: warning: variable "addr" was declared but never referenced
"SVG_interupt.c", line 306: error: unrecognized token
"SVG_interupt.c", line 306: error: expected an expression
13 errors detected in the compilation of "SVG_interupt.c".
>> Compilation failure
[SVG_main.c] "C:\CCStudio_v3.3\C2000\cgtools\bin\cl2000" -g -fr"C:/CCStudio_v3.3/MyProjects/svg/svg/Debug" -i"C:/CCStudio_v3.3/MyProjects/svg/include" -d"_DEBUG" -d"LARGE_MODEL" -ml -v28 -@"../svg/Debug.lkf" "SVG_main.c"
回复评论 (3)
解决了,原来是少一个注释号
点赞  2010-8-24 10:23
解决了,原来是少一个注释号
请问是少了什么注释号,我也出现这个问题...谢谢了~
点赞  2011-6-13 10:14
j = *(UNIT_VOL_BASEADDR + wUintIndex );  //  直流电压遥测
少了这个。哈哈
工程 = 数学+物理+经济
点赞  2011-10-11 08:33
    写回复
