[求助] 求助:自己设计的IIR滤波器
sakya   2010-9-15 10:17 楼主
昨天自己设计了一个IIR滤波器,写了个测试程序:滤波器是一个低通的滤波器,要求滤除20KHZ以上的频率段,
程序如下:
#include "filter.h"
#include "iir.h"
#include "math.h"
float xn[400],yn[400],zn[400],rn[400];
#pragma DATA_SECTION(iir, "iirfilt");
IIR5BIQ16 iir=IIR5BIQ16_DEFAULTS;
#pragma DATA_SECTION(dbuffer,"iirfilt");
int dbuffer[2*IIR16_LPF_NBIQ];
const int coeff[5*IIR16_LPF_NBIQ]=IIR16_LPF_COEFF;
int i;
main ()
//        int i;
        float w1,w2,t;
下面是自己写的25K和15K频率的合成的波形
        w1=2*3.1415926*25000;
        for(i=0;i<400;i++)
            xn=sin(w1*t);
            t+=0.000001;
         w2=2*3.1415926*15000;
         for(i=0;i<400;i++)
            yn=sin(w2*t);
            t+=0.000001;
         for(i=0;i<400;i++)
            rn=xn+yn;
下面是滤波程序
        iir.dbuffer_ptr=dbuffer;
        iir.coeff_ptr=(int *)coeff;
        iir.qfmat=IIR16_LPF_QFMAT;
        iir.nbiq=IIR16_LPF_NBIQ;
        iir.isf=IIR16_LPF_ISF;
        iir.init(&iir);
        for(i=0;i<400;i++)
        iir.input=(rn);
        iir.calc(&iir);
        zn=iir.output;
        while(1)
滤波头的设计是:
>> eziir16
ezIIR FILTER DESIGN SCRIPT
Butterworth       : 1
Chebyshev(Type 1) : 2
Chebyshev(Type 2) : 3
Elliptic          : 4
Select Any one of the above IIR Filter Type     : 1
Low pass          : 1
High Pass         : 2
Band Pass         : 3
Band Stop         : 4
Select Any one of the above Response            : 1
Enter the Sampling frequency                    : 96000
Enter the Pass band Ripples in dB(RP)           : 1
Enter the stop band Rippled in dB(RS)           : 20
Enter the pass band corner frequency(FP)        : 20000
Enter the stop band corner frequency(FS)        : 21000
Enter the name of the file for coeff storage    : filter.h
Q format of the IIR filter coefficients:
Input Scaling value:
    0.8763
Number of Biquads:
    23
生成的头文件的代码是:
#define IIR16_COEFF {\
                        0,8,0,6,6,\
                        -1,16,12,25,12,\
                        -1,16,12,25,12,\
                        -2,16,13,25,13,\
                        -2,16,13,25,13,\
                        -3,16,13,26,13,\
                        -4,17,13,26,13,\
                        -5,17,13,27,13,\
                        -6,17,14,27,14,\
                        -8,17,14,28,14,\
                        -9,18,14,28,14,\
                        -11,18,15,29,15,\
                        -14,19,15,30,15,\
                        -16,20,15,31,15,\
                        -19,20,16,32,16,\
                        -22,21,17,33,17,\
                        -26,22,17,34,17,\
                        -30,23,17,35,17,\
                        -34,24,18,36,18,\
                        -40,25,18,36,18,\
                        -46,27,17,34,17,\
                        -52,28,11,23,11,\
                        -60,30,13320,26640,13320}
#define IIR16_ISF        56
#define IIR16_NBIQ        23
#define IIR16_QFMAT        6
但是自己在测试的时候发现输出的zn的波形不是和yn相似??请问为什么?
回复评论 (1)
对数字滤波器的设计一直都很感兴趣只是近期没有时间研究,希望有人能给你解疑。
工程 = 数学+物理+经济
点赞  2010-9-15 12:49
    写回复
