ULINK2 常见有下面5类 扁平电缆接口:
我经常使用的20 PIN interface (2.54mm) 间距的接口。
上面5类JTAG接口管脚定义如下:
管脚信号含义:
TMS | Test Mode State pin — Use 100K Ohm pull-up resistor to VCC. |
TDO | Test Data Out pin. |
RTCK | JTAG Return Test ClocK. (see Note below) |
TDI | Test Data In pin — Use 100K Ohm pull-up resistor to VCC. |
TRST | Test ReSeT/ pin — Use 100K Ohm pull-up resistor to VCC. TRST is optional and not available on some devices. You may leave it unconnected. |
TCLK | Test CLocK pin — Use 100K Ohm pull-down resistor to GND. |
VCC | Positive Supply Voltage — Power supply for JTAG interface drivers. |
GND | Digital ground. |
RESET | RSTIN/ pin — Connect this pin to the (active low) reset input of the target CPU. |
CPUCLK | CPU clock (according IEEE Standard 1149.1). |
OCDSE | Enable/Disable OCDS interface (Infineon-specific). |
TRAP | Trap condition (Infineon-specific). |
BRKIN | Hardware break in (Infineon-specific). |
BRKOUT | Hardware break out (Infineon-specific). |
/JEN | JTAG Enable (STMicroelectronics specific). |
TSTAT | JTAG ISP Status (STMicroelectronics specific) (optional). |
/RST | Chip reset (STMicroelectronics specific). |
/TERR | JTAG ISP Error (STMicroelectronics specific) (optional). |
