汽车电子可参考的文献列表
yulzhu   2010-12-24 22:53 楼主
以下为可参考的有关基础知识的公开出版物,有些非公开的就不在此列。
A.3.1应用文档
A.3.1 概览
汽车半导体技术市场一览
A.3.2 电阻
TT Current Sensing Resistors
TT Pulse & Overload Capability Of Wirewound Resistor
KOA ESD Test Data RK73H Series
KOA Limitations Of Potential Pulsing On Thick Film Flat Chip Resistors
KOA Terms And Definitions Environmental Applications
KOA Thermal Resistance Details For Flat Chip Resistors
Vishey Resistor Sensitivity To Electrostatic Discharge(ESD)
TDK MLCC ESD Guide
TI Input And Output Capacitor Selection
SSM Data Book Ultra-Precision &Ultra-Reliability Thin Film Chip Resistors
Stress Effects On Thin Film Nichrome Embedded Resistor Tolerance
A.3.3电容
关于旁路电容的深度对话
十说电容
AVX Surge Current Testing Of Resin Dipped Tantalum Capacitors
AVX Surge In Solid Tantalum Capacitors
CDE Aluminum Electrolytic Capacitors Application Guide
Nichicon Application Guidelines For Aluminum Electrolytic Capacitors
Nichicon General Description Of Aluminum Electrolytic Capacitors
Nippon Chemi-Con Life Expectancy Method
Kemet MLCC ESD
Kendail Guidelines For Aluminium Electrolytic Capacitors
Quadtech Equivalent Series Resistance (ESR) Of Capacitorsr
Hitachi Electrolytic Capacitors
EPCOS General Technical Information
Effect Of Moisture On Characteristics Of Surface Mount Solid Tantalum
Electrolytic Capacitor Lifetime Estimation
ESR Calculations For Electrolytic Capacitors At Lower Temperatures
Voltage Derating Rules For Solid Tantalum & Niobium Capacitors
Evoxrifa Life-Limiting Factors In Electrolytic Capacitors
Evoxrvar Electrolytic Capacitors Application Guide
PSA MLCC Application Guide
Sencore Understanding ESR In Capacitors
Illinois Life Calculators
A.3.4 二极管
Design Considerations And Performance Of Motorola Temperature-Compensated Zener (Reference) Diodes
ST Low Forward Voltage Schottky Diode
How To Use Zener Diodes.Doc
Schottky Diodes White Paper
IXAN0044 Fast Recovery Epitaxial Diodes
Free-Wheeling Diodes With Improved Reverse Recovery
Reverse Recovery Time
A.3.5晶体管和场效应管
Renesas 小信号晶体管使用时的注意事项和免责事项
Renesas 功率MOSFET结构与特点
Renesas 功率MOSFET使用时的注意事项1
Renesas 功率MOSFET使用时的注意事项2
Renesus Power MOSFET Application Note
Renesus Power MOSFET应用说明
Infenion AN-Avalanche-FET
Infenion Application Note MOSFET Losses
Infenion Guideline For Determining Switching Losses Associated With Switching Resistive,Capacitive And Inductive Loads
Infenion  Parasitic Turn-On Of Power MOSFET
Infenion Reverse Batery Protection Rev2
Infenion Thermal Resistance Calculation
Infenion Three Ways To Calculate The Voltage Transients In Power MOSFET
ST AN1596 Hsd Automotive
ST AN2208 Designing Industrial Applications With Vn808vn340sp High-Side Drivers
TI Design And Application Guide For High Speed MOSFET Gate Drive Circuits
TI Optimizing MOSFET Characteristics By Adjusting Gate Drive Amplitude
MICROCHIP AN799 MOSFET 驱动器与MOSFET 的匹配设计
TI Reverse Current battery Protection Circuits
Fairchild AN9304 Power MOSFET Avalanche Guideline
A.3.6单片机
Freescale AN1058 Reducing AD Errors In Microcontroller Applications
Freescale AN1083 Basic Thermal Managment Of Power Semi Conductors
Freescale AN1570 Basic Semiconductor Thermal Measurement
Freescale AN1706 Microcontroller Oscillator Circuit Design Considerations
Freescale AN1744 Resetting Microcontrollers During Power Transitions
Freescale AN1783 Determining MCU Oscillator Start-Up Parameters
Freescale AN2429 Interfacing To The HCS12 ATD Module
Freescale AN2434 IO Pin Drivers On HCS12Family Mcus
Freescale AN2438 ADC Definitions And Specifications
Freescale AN2764 Improving The Transient Immunity Performance Of Microcontroller-Based Applications
Freescale AN3208 Crystal Oscillator Troubleshooting Guide
Freescale EB258 Sources Of Reset On Modular Microcontrollers
Freescale EB413 Resetting Mcus
ST AN 1636 Understanding And Minimizing ADC Conversion Errors
ST EMC Design Guide For ST Microcontrollers
ADI Recommended Handling Of Unused Pins
Xinilix Understanding True CMOS Outputs
A.3.7 继电器
Tyco 1308028 Automotive Relays And Switching Modules Glossary
Tyco 13C3226 Temperature Considerations For DC Relays
Tyco 13C3236 Relay Contact Life
Tyco 13C3264 Coil Suppression Can Reduce Relay Life
Tyco 13C3311 Application Of Coil Suppression With DC Relays
Tyco 13C3344 Determining Relay Coil Inductance
Matsushita Relay Technical Information Guidelines And Application
A.3.8 MOV
Varistors Ideal Solution To Surge Protection
A.3.9 TVS
Onsemi PCB Design Guidelines For Dual Power Supply Voltage Translators
Onsemi PCB Design Guidelines That Maximize The Performance Of TVS Diodes
Littlefuse Transient Suppression Devices And Principles
Microsemi Derating TVS Devices For Higher Junction Temp
Microsemi Determining Clamping Voltages For Pulse Currents
Microsemi Overall TVS Selection
Vishey Determining Clamping Voltage Levels For A Broad Range Of Pulse Currents
Vishey Transient Suppressors, A Competitive Look
Onsemi Transient Overvoltage Protection
Onsemi TVS Diode Selection Guidelines For The CAN Bus
Onsemi TVS,Zener Theory And Design Considerations Handbook
A.3.10 LDO
NS AN1148 线性稳压器:工作原理极其补偿
TI Understanding The Load-Transient Response Of LDOs
TI Understanding The Stable Range Of Equivalent Series Resistance Of An LDO Regulator
TI Understanding The Terms And Definitions Of LDO Voltage
TI Digital Designer’s Guide To Linear Voltage Regulators And Thermal Management
A.3.11 PCB
印制电路板拼板的研究与开发
ORCAD原理图设计规范
Renesas 贴装手册
PCB Trace Temperature Rise
PCB Current Carrying Capacity
2007 IEEE EMC Symposium Circuit Board Layout For Automotive Electronics
Motorola 电路板级的电磁兼容设计
Solder Joint Reliability Predictions For Leadless Chip Resistors, Chip Capacitors, And Ferrite Chip Inductors Using The SRS Software
A.3.12 FUSE
Cooper Fuse Technology
Littelfuse Fuseology Automotive
A.3.2 设计方法
A.3.1 可靠性预测
GJBZ 108A-2006 电子设备非工作状态可靠性预计手册
GJBZ 299C-2006 电子设备可靠性预计手册
SAEJ1211 Handbook for Robustness Validation of Automotive Electrical/Electronic Modules
SAEJ1879 Handbook for Robustness Validation of Semiconductor Devices in Automotive Applications
Renesas 可靠性手册
MIL-HDBK-217F
A.3.2 最坏分析和容差分析
GJBZ 223-2005 最坏情况电路分析指南
GJBZ 89-97 电路容差分析指南
WINNET Pspice Training Material
Using Mathcad To Solve Laplace Transforms
A.3.3 失效模式分析
失效模式与后果分析FMEA第四版
GJBZ 1391-2006故障模式、影响及危害性分析指南
A.3.4 热分析
JESD51标准
创立达 IC封装热阻的定义与量测技术
热分析与热设计技术Paulralko
Onsemi AN569 Transient Thermal Resistance General Data And Its Use
Onsemi AND8036 Thermal Management
Vishey Pulse Power Rating Of Semiconductors
General Semi AN102 Using The Power Vs Time Curve
A.3.5 其他
GBT 7829-200X 故障树分析
生产件批准程序PPAP手册第三版.Doc
产品质量先期策划和控制计划APQP参考手册
TS16949-2002 (English)
P.L.Clemens Sneak Circuit Analysis
Ericson-FTA-Tutorial
A.3.3 其他
Load Dump Pulses According To Various Test Requirementsone Phenomenon–Two Methods Of Generation–A Comparison
Calculating Optimum Sunbbers
CDE Application Guide Snubber Capacitors
Snubber Circuits
回复评论 (5)
这么多啊,够看的了,有用就过来拿喽
我爱电子!
点赞  2010-12-26 09:30
这么多啊!
点赞  2010-12-26 20:25
加油!在电子行业默默贡献自己的力量!:)
点赞  2011-1-3 20:50
这个 这么多英文的吗?
点赞  2011-8-21 09:46
偶的英文不够级
点赞  2011-8-26 15:16
    写回复
