#define FLASH_BASE 0x00000000 // FLASH memory
#define SRAM_BASE 0x20000000 // SRAM memory
#define WATCHDOG0_BASE 0x40000000 // Watchdog0
#define WATCHDOG1_BASE 0x40001000 // Watchdog1
#define GPIO_PORTA_BASE 0x40004000 // GPIO Port A
#define GPIO_PORTB_BASE 0x40005000 // GPIO Port B
#define GPIO_PORTC_BASE 0x40006000 // GPIO Port C
#define GPIO_PORTD_BASE 0x40007000 // GPIO Port D
#define SSI0_BASE 0x40008000 // SSI0
#define SSI1_BASE 0x40009000 // SSI1
#define UART0_BASE 0x4000C000 // UART0
#define UART1_BASE 0x4000D000 // UART1
#define UART2_BASE 0x4000E000 // UART2
#define I2C0_MASTER_BASE 0x40020000 // I2C0 Master
#define I2C0_SLAVE_BASE 0x40020800 // I2C0 Slave
#define I2C1_MASTER_BASE 0x40021000 // I2C1 Master
#define I2C1_SLAVE_BASE 0x40021800 // I2C1 Slave
#define GPIO_PORTE_BASE 0x40024000 // GPIO Port E
#define GPIO_PORTF_BASE 0x40025000 // GPIO Port F
#define GPIO_PORTG_BASE 0x40026000 // GPIO Port G
#define GPIO_PORTH_BASE 0x40027000 // GPIO Port H
#define PWM_BASE 0x40028000 // PWM
#define QEI0_BASE 0x4002C000 // QEI0
#define QEI1_BASE 0x4002D000 // QEI1
#define TIMER0_BASE 0x40030000 // Timer0
#define TIMER1_BASE 0x40031000 // Timer1
#define TIMER2_BASE 0x40032000 // Timer2
#define TIMER3_BASE 0x40033000 // Timer3
#define ADC0_BASE 0x40038000 // ADC0
#define ADC1_BASE 0x40039000 // ADC1
#define COMP_BASE 0x4003C000 // Analog comparators
#define GPIO_PORTJ_BASE 0x4003D000 // GPIO Port J
#define CAN0_BASE 0x40040000 // CAN0
#define CAN1_BASE 0x40041000 // CAN1
#define CAN2_BASE 0x40042000 // CAN2
#define ETH_BASE 0x40048000 // Ethernet
#define MAC_BASE 0x40048000 // Ethernet
#define USB0_BASE 0x40050000 // USB 0 Controller
#define I2S0_BASE 0x40054000 // I2S0
#define GPIO_PORTA_AHB_BASE 0x40058000 // GPIO Port A (high speed)
#define GPIO_PORTB_AHB_BASE 0x40059000 // GPIO Port B (high speed)
#define GPIO_PORTC_AHB_BASE 0x4005A000 // GPIO Port C (high speed)
#define GPIO_PORTD_AHB_BASE 0x4005B000 // GPIO Port D (high speed)
#define GPIO_PORTE_AHB_BASE 0x4005C000 // GPIO Port E (high speed)
#define GPIO_PORTF_AHB_BASE 0x4005D000 // GPIO Port F (high speed)
#define GPIO_PORTG_AHB_BASE 0x4005E000 // GPIO Port G (high speed)
#define GPIO_PORTH_AHB_BASE 0x4005F000 // GPIO Port H (high speed)
#define GPIO_PORTJ_AHB_BASE 0x40060000 // GPIO Port J (high speed)
#define EPI0_BASE 0x400D0000 // EPI0
#define HIB_BASE 0x400FC000 // Hibernation Module
#define FLASH_CTRL_BASE 0x400FD000 // FLASH Controller
#define SYSCTL_BASE 0x400FE000 // System Control
#define UDMA_BASE 0x400FF000 // uDMA Controller
#define ITM_BASE 0xE0000000 // Instrumentation Trace Macrocell
#define DWT_BASE 0xE0001000 // Data Watchpoint and Trace
#define FPB_BASE 0xE0002000 // FLASH Patch and Breakpoint
#define NVIC_BASE 0xE000E000 // Nested Vectored Interrupt Ctrl
#define TPIU_BASE 0xE0040000 // Trace Port Interface Unit
// The following definitions are deprecated.
#ifndef DEPRECATED
// The following are deprecated defines for the base address of the memories
// and peripherals.
#define WATCHDOG_BASE 0x40000000 // Watchdog
#define SSI_BASE 0x40008000 // SSI
#define I2C_MASTER_BASE 0x40020000 // I2C Master
#define I2C_SLAVE_BASE 0x40020800 // I2C Slave
#define QEI_BASE 0x4002C000 // QEI
#define ADC_BASE 0x40038000 // ADC
该头文件定义了 外设的基址,注意后边几个是不推荐使用的。
比如,在配置ADC时推荐使用
ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
而非
ADCSequenceConfigure(ADC_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
