我用的是IAR。编译没有问题啊!只是在运作的时候,分配太大就会返回NULL。
搜索看到有的贴子说是512字节。不知道可不可以改。
请看黑体部分,你可以在链接脚本里分配HEAP的大小,但不建议你用这种方法,你可以考虑一下使用POOL方式,
uc/OS-II里有一个简单的POOL管理实现方法.
// Define a memory region that covers the entire 4 GB addressible space of the
// processor.
define memory mem with size = 4G;
// Define a region for the on-chip flash.
define region FLASH = mem:[from 0x8000000 to 0x807FFFF];
// Define a region for the on-chip SRAM.
define region SRAM = mem:[from 0x20000000 to 0x2000BFFF];
// Define a block for the heap. The size should be set to something other
// than zero if things in the C library that require the heap are used.
define block HEAP with alignment = 8, size = 0x00001000 { };
define block CSTACK with alignment = 8, size = 0x00000400 { };
// Indicate that the read/write values should be initialized by copying from
// flash.
initialize by copy { readwrite };
// Initicate that the noinit values should be left alone. This includes the
// stack, which if initialized will destroy the return address from the
// initialization code, causing the processor to branch to zero and fault.
do not initialize { section .noinit };
// Place the interrupt vectors at the start of flash.
place at start of FLASH { readonly section .intvec };
// Place the remainder of the read-only items into flash.
place in FLASH { readonly };
// Place all read/write items into SRAM.
place in SRAM { readwrite, block HEAP, block CSTACK};
非常感谢!我也找到了icf文件,并且更改测试确定更改后是有变化的。
但是,就是担心更改了会不会对其他的地方有影响呢。
所以,我也不倾向与更改。
不知道香版的意见呢!
只要改了之后内存分配不产生冲突,就不会对其他的地方有影响。
改堆的大小不会影响其它的地方,只是空闲的RAM空间变小了。
