中断没反应,请大家帮忙看一下
huleisheng   2010-1-25 10:36 楼主
目的:想用外部中断测试CAN实现自发自收。首先点亮全部的LED灯,按下键一以CAN_Polling收发数据,如果成功则熄灭一个LED灯,否则熄灭相邻的一个LED灯。按下键2以CAN_Interrupt收发数据,如果成功则熄灭一个LED灯。否则熄灭相邻的一个LED灯。但是实验总不成功。刚学这个,还请大家指点一下
   主程序:
  RCC_Configuration();
  GPIO_Configuration();
  NVIC_Configuration();
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_Pin_3 | GPIO_Pin_4);
  EXTI_InitStructure.EXTI_Line = EXTI_Line3 | EXTI_Line4;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  EXTI_GenerateSWInterrupt(EXTI_Line3 | EXTI_Line4);
/*循环点亮LED1-LED4*/
  while (1)
   GPIO_SetBits(GPIOC, GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7);
中断程序:
void EXTI3_IRQHandler(void)
  while (EXTI_GetITStatus(EXTI_Line3) != RESET)
   TestRx = CAN_Polling();
  if (TestRx == FAILED)
    GPIO_ResetBits(GPIOC, GPIO_Pin_4);
  else
    GPIO_ResetBits(GPIOC, GPIO_Pin_5);
   EXTI_ClearITPendingBit(EXTI_Line3);
void EXTI4_IRQHandler(void)
while (EXTI_GetITStatus(EXTI_Line4) != RESET)
  TestRx = CAN_Interrupt();
    GPIO_ResetBits(GPIOC, GPIO_Pin_6);
  else
        GPIO_ResetBits(GPIOC, GPIO_Pin_7);
    EXTI_ClearITPendingBit(EXTI_Line4);
回复评论 (5)
中断没反应?
就是说按键之后,进不了EXTI中断么?
常见原因就是没有使能AFIO时钟~~~
点赞  2010-1-25 11:47
是的,就是按键之后没进入中断处理,RCC配置是下面的:
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x04)
  /* GPIOD and GPIOC clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOC
                         | RCC_APB2Periph_AFIO, ENABLE);
  /* CAN Periph clock enable */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
点赞  2010-1-25 12:33
如此看来,时钟配置没有问题;
那么再看看
1)EXTI配置的“falling edge”产生中断,和板子上的按钮连接是否相符;
但是看到后面是用软件模拟外部中断也未果的话,考虑
2)中断NVIC的配置未知。。。
点赞  2010-1-25 14:11
                                 外部中断开了吗
点赞  2010-1-25 15:52
提示: 作者被禁止或删除 内容自动屏蔽
点赞  2010-1-26 11:42
    写回复
