2者都是hid 类的,如果想把他们做在一起,应该如何实现呢?
按下面的配置描述可以识别成键盘,也没有报错,但是如何启用Alternate setting1呢?
const u8 Joystick_ConfigDescriptor[JOYSTICK_SIZ_CONFIG_DESC] =
/*offset 0*/
//以下为配置描述符
0x09, /* bLength: Configuation Descriptor size */
USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
JOYSTICK_SIZ_CONFIG_DESC, /* wTotalLength: Bytes returned ;2字节*/
0x00,
0x01, /*bNumInterfaces: 1 interface;接口数量*/
0x01, /*bConfigurationValue: Configuration value*/
0x00, /*iConfiguration: Index of string descriptor describing the configuration*/
0xC0, /*bmAttributes: self powered */
0x32, /*MaxPower 100 mA: this current is used for detecting Vbus*/
//以下为接口描述符1
/************** Descriptor of Joystick Mouse interface ****************/
/*offset 9 */
0x09, /*bLength: Interface Descriptor size*/
USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type接口描述类型*/
0x00, /*bInterfaceNumber: Number of Interface*/
0x00, /*bAlternateSetting: Alternate setting 可选设置的索引值。xx1*/
0x02, /*bNumEndpoints*/
0x03, /*bInterfaceClass: HID*/
0x00, /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
0x01, /*bInterfaceProtocol : 键盘 0=none, 1=keyboard, 2=mouse*/
0, /*iInterface: Index of string descriptor*/
/******************** Descriptor of Joystick Mouse HID ********************/
/*offset 18 */
0x09, /*bLength: HID Descriptor size*/
HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID HID描述符*/
0x00, /*bcdHID: HID Class Spec release number*/
0x01,
0x00, /*bCountryCode: Hardware target country*/
0x01, /*bNumDescriptors: Number of HID class descriptors to follow*/
0x22, /*bDescriptorType*/
JOYSTICK_SIZ_REPORT_DESC,/*wItemLength: Total length of Report descriptor*/
0x00,
/******************** Descriptor of Joystick Mouse endpoint ********************/
/*offset 27 */
0x07, /*bLength: Endpoint Descriptor size*/
USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:输入端点1描述符*/
0x81, /*bEndpointAddress: Endpoint Address (IN)*/
0x03, /*bmAttributes: Interrupt endpoint*/
0x08, /*wMaxPacketSize: 8 Byte max */
0x00,
0x20, /*bInterval: Polling Interval (32 ms)*/
/*offset 34 */
USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:输出端但1描述符*/
0x01, /*bEndpointAddress: Endpoint Address (OUT)*/
0x00,
//以下为接口描述符2
/************** Descriptor of Custom HID interface ****************/
/*offset 41 */
0x09, /* bLength: Interface Descriptor size */
USB_INTERFACE_DESCRIPTOR_TYPE,/* bDescriptorType: Interface descriptor type接口描述类型 */
0x00, /* bInterfaceNumber: Number of Interface */
0x01, /* bAlternateSetting: Alternate setting */
0x02, /* bNumEndpoints */
0x03, /* bInterfaceClass: HID */
0x00, /* bInterfaceSubClass : 1=BOOT, 0=no boot */
0x00, /* nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse */
0, /* iInterface: Index of string descriptor */
/******************** Descriptor of Custom HID HID ********************/
/*offset 50 */
0x09, /* bLength: HID Descriptor size */
HID_DESCRIPTOR_TYPE, /* bDescriptorType: HID HID描述类型*/
0x10, /* bcdHID: HID Class Spec release number */
0x01,
0x00, /* bCountryCode: Hardware target country */
0x01, /* bNumDescriptors: Number of HID class descriptors to follow */
0x22, /* bDescriptorType */
CUSTOMHID_SIZ_REPORT_DESC, /* wItemLength: Total length of Report descriptor */
0x00,
/******************** Descriptor of Custom HID endpoints ******************/
/*offset 59 */
0x07, /* bLength: Endpoint Descriptor size */
USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: 端点描述类型*/
0x81, /* bEndpointAddress: Endpoint Address (IN) */
0x03, /* bmAttributes: Interrupt endpoint */
0x02, /* wMaxPacketSize: 2 Bytes max */
0x00,
0x20, /* bInterval: Polling Interval (32 ms) */
/* offset 59+7=66 */
USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: Endpoint descriptor type */
0x01, /* bEndpointAddress: Endpoint Address (OUT) */
0x00,
0x20, /* bInterval: Polling Interval (20 ms) */
/* offset 66+7=73 */
楼上的正解。
我本想把圈圈的源码发上来,但怕侵犯圈圈的权利。
我把我修改的部分发上来吧。用的是“多Collection的方式,用Report ID区分”这种。
在custom hid例子上修改的。
const uint8_t CustomHID_ReportDescriptor[CUSTOMHID_SIZ_REPORT_DESC] =
0x05, 0x8c, /* USAGE_PAGE (ST Page) */
0x09, 0x01, /* USAGE (Demo Kit) */
0xa1, 0x01, /* COLLECTION (Application) */
/* 6 */
/* Led 1 */
0x85, 0x01, /* REPORT_ID (1) */
0x09, 0x01, /* USAGE (LED 1) */
0x15, 0x00, /* LOGICAL_MINIMUM (0) */
0x25, 0x01, /* LOGICAL_MAXIMUM (1) */
0x75, 0x08, /* REPORT_SIZE (8) */
0x95, 0x01, /* REPORT_COUNT (1) */ //一个 字节
0xB1, 0x82, /* FEATURE (Data,Var,Abs,Vol) */
0x85, 0x01, /* REPORT_ID (1) */ //上面是定义,下面使用?
0x91, 0x82, /* OUTPUT (Data,Var,Abs,Vol) */ //PC->dev
/* 26 */
/* Led 2 */
0x85, 0x02, /* REPORT_ID 2 */
0x09, 0x02, /* USAGE (LED 2) */
0x85, 0x02, /* REPORT_ID (2) */
/* 46 */
/* Led 3 */
0x85, 0x03, /* REPORT_ID (3) */
0x09, 0x03, /* USAGE (LED 3) */
/* 66 */
/* Led 4 */
0x85, 0x04, /* REPORT_ID 4) */
0x09, 0x04, /* USAGE (LED 4) */
0x85, 0x04, /* REPORT_ID (4) */
/* 86 */
/* key Push Button */
0x85, 0x05, /* REPORT_ID (5) */
0x09, 0x05, /* USAGE (Push Button) */
0x75, 0x01, /* REPORT_SIZE (1) */
0x81, 0x82, /* INPUT (Data,Var,Abs,Vol) */ //输出1位按键信号
0xb1, 0x82, /* FEATURE (Data,Var,Abs,Vol) */ //上面定义,下面使用,输出到pc1位有效信号
0x75, 0x07, /* REPORT_SIZE (7) */
0x81, 0x83, /* INPUT (Cnst,Var,Abs,Vol) */ //输出7位无效信号,凑满1字节
0xb1, 0x83, /* FEATURE (Cnst,Var,Abs,Vol) */
/* 114 */
/* Tamper Push Button */
0x85, 0x06, /* REPORT_ID (6) */
0x09, 0x06, /* USAGE (Tamper Push Button) */
/* 142 */
/* ADC IN */
0x85, 0x07, /* REPORT_ID (7) */
0x09, 0x07, /* USAGE (ADC IN) */
0x26, 0xff, 0x00, /* LOGICAL_MAXIMUM (255) */
0x09, 0x07, /* USAGE (ADC in) */
/* 161 */
0xc0, /* END_COLLECTION */
//--------按键部分---------------------------------------------------------
/* offset 162 */
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x06, // USAGE (Keyboard)
0xa1, 0x01, // COLLECTION (Application)
0x85, 0x08, /* REPORT_ID (8) */
/* offset 170 */
0x05, 0x07, // USAGE_PAGE (Keyboard/Keypad)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl) LCtrl,LShift,LAlt,LGUI,RCtrl,RShift,RAlt,RGUI
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)//总共是8个按键0xe0~0xe7
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
/* offset 180 */
0x95, 0x08, // REPORT_COUNT (8)
0x75, 0x01, // REPORT_SIZE (1) //单位为bit
0x81, 0x02, // INPUT (Data,Var,Abs) //to PC 一个字节(1st)控制键部分
0x95, 0x01, // REPORT_COUNT (1)
0x75, 0x08, // REPORT_SIZE (8)
/* offset 190 */
0x81, 0x03, // INPUT (Cnst,Var,Abs) //to pc 一个字节(2nd)
0x95, 0x06, // REPORT_COUNT (6) //to pc 6个字节(3rd~8th)
0x25, 0xFF, // LOGICAL_MAXIMUM (255)
0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated))
/* offset 200 */
0x29, 0x65, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0x25, 0x01, // LOGICAL_MAXIMUM (1)//大小写等led部分,需要
0x95, 0x02, // REPORT_COUNT (2)
/* offset 210 */
0x05, 0x08, // USAGE_PAGE (LEDs)
0x19, 0x01, // USAGE_MINIMUM (Num Lock)
0x29, 0x02, // USAGE_MAXIMUM (Caps Lock)
0x91, 0x02, // OUTPUT (Data,Var,Abs) //2位有效信号led
/* offset 220 */
0x75, 0x06, // REPORT_SIZE (6)
0x91, 0x03, // OUTPUT (Cnst,Var,Abs) //剩下的6位,补足1字节
0xc0 // END_COLLECTION
/* offset 225 */
}; /* CustomHID_ReportDescriptor */
const uint8_t CustomHID_ConfigDescriptor[CUSTOMHID_SIZ_CONFIG_DESC] =
CUSTOMHID_SIZ_CONFIG_DESC,
/* wTotalLength: Bytes returned */
0x00,
0x01, /* bNumInterfaces: 1 interface */
0x01, /* bConfigurationValue: Configuration value */
0x00, /* iConfiguration: Index of string descriptor describing
the configuration*/
0xC0, /* bmAttributes: Bus powered */
0x32, /* MaxPower 100 mA: this current is used for detecting Vbus */
/* 09 */
USB_INTERFACE_DESCRIPTOR_TYPE,/* bDescriptorType: Interface descriptor type */
0x00, /* bAlternateSetting: Alternate setting */
/* 18 */
HID_DESCRIPTOR_TYPE, /* bDescriptorType: HID */
0x01,
CUSTOMHID_SIZ_REPORT_DESC,/* wItemLength: Total length of Report descriptor */
0x00,
/* 27 */
USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */
0x10, /* wMaxPacketSize: 16 Bytes max */
0x00,
/* 34 */
/* Endpoint descriptor type */
0x01, /* bEndpointAddress: */
/* Endpoint Address (OUT) */
0x00,
/* 41 */
; /* CustomHID_ConfigDescriptor */
