程序中使用了TIM2,UART1,UART2和ADC+DMA1中断,不加上UART2时都正常,加上UART2中断后,运行几分钟后ADC+DMA1的中断就不能进去了,更改了几种中断优先级方式后都没有解决。请大家看看是什么原因?
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Configure one bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* Enable the TIM2 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Enable the DMA channel1 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
/* Enable Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;
// NVIC_Init(&NVIC_InitStructure);
但定时中断一直能正常运行,启动ADC,
void TIM2_IRQHandler(void)
static INT16U count = 0;
if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
ADC_SoftwareStartConvCmd(ADC1,ENABLE);
// Start ADC1 Software Conversion
capture = TIM_GetCapture1(TIM2);
TIM_SetCompare1(TIM2, capture + TimerCount_500);
else if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
capture = TIM_GetCapture2(TIM2);
TIM_SetCompare2(TIM2, capture + CCR2_Val);
else if (TIM_GetITStatus(TIM2, TIM_IT_CC3) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
capture = TIM_GetCapture3(TIM2);
TIM_SetCompare3(TIM2, capture + CCR3_Val);
else
TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
capture = TIM_GetCapture4(TIM2);
TIM_SetCompare4(TIM2, capture + CCR4_Val);
void DMA1_Channel1_IRQHandler(void)
static INT8U channel = 0;
static INT8U vchannel = 0;
if(DMA_GetITStatus(DMA1_IT_TC1)==SET)
gAllSampleData[channel]= ADC_ConvertedValue[0]&0x0fff; //ADC_IN0
gVSampleData[vchannel] = ADC_ConvertedValue[1]&0x0fff; //ADC_IN1
gDCSampleData[channel] = ADC_ConvertedValue[2]&0x0fff; //ADC_IN8
if(++channel ==4){
//一次的采样完成,设置数据处理标志位
channel = 0;
ADFinished = TRUE;
else {
ADC_SoftwareStartConvCmd(ADC1,ENABLE); /* Start ADC1 Software Conversion */
DMA_ClearITPendingBit(DMA1_IT_TC1);
else if(DMA_GetITStatus(DMA1_IT_HT1)==SET)
DMA_ClearITPendingBit(DMA1_IT_HT1);
void USART1_IRQHandler(void)
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
UART1_Rec_Isr();
/* Clear the USART1 Receive interrupt */
USART_ClearITPendingBit(USART1, USART_IT_RXNE);
else if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
UART1_Send_Isr();
USART_ClearITPendingBit(USART1, USART_IT_TXE);
* Function Name : USART2_IRQHandler
* Description : This function handles USART2 global interrupt request.
* Input : None
* Output : None
* Return : None
void USART2_IRQHandler(void)
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
UART2_Rec_Isr();
USART_ClearITPendingBit(USART2, USART_IT_RXNE);
else if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
UART2_Send_Isr();
USART_ClearITPendingBit(USART2, USART_IT_TXE);
