芯片 : STM32F107 (72Mhz)
FLASH:AT45DB161D
现在写入了“1234”4个字符
设置 SPI_BaudRatePrescaler 为 SPI_BaudRatePrescaler_256时,读取到
0x00 0x31 0x32 0x33 0x34 .....
设置 SPI_BaudRatePrescaler 为 SPI_BaudRatePrescaler_2时,读取到
0x00 0x32 0x33 0x34 .....
不知道怎么回事???
单步调试时都正常
我之前发送和接收SPI数据的函数是
static u8 Spi_ReadByte(void)
while(SPI_I2S_GetFlagStatus(FLASH_SPI, SPI_I2S_FLAG_BSY) == SET);
while (SPI_I2S_GetFlagStatus(FLASH_SPI, SPI_I2S_FLAG_TXE) == RESET);
FLASH_SPI->DR = FLASH_DUMMY_BYTE;
while (SPI_I2S_GetFlagStatus(FLASH_SPI, SPI_I2S_FLAG_RXNE) == RESET);
return FLASH_SPI->DR;
static void Spi_WriteByte(u8 data)
FLASH_SPI->DR = data;
现在改为了共用一个函数
u8 Spi_WriteByte(u8 byte)
SPI_I2S_SendData(FLASH_SPI, byte);
return SPI_I2S_ReceiveData(FLASH_SPI);
就这样,SPI FLASH读写就OK了
应该是时序的问题吧?我也遇到了,但是没有你的运气好,按STM32固件库的sFlash demo改也未奏效。
后来分析是读写时钟边沿不同产生的时序问题。单步调试正常是因为把操作时序人为拉长了,实际效果等于对齐了TXE和RXNE的操作。如果我的分析正确,你的代码很有可能是碰巧对了,一旦程序运行时序变化,还有可能出错。
下面是摘录的库内demo代码
define sFLASH_CS_LOW() GPIO_ResetBits(sFLASH_CS_GPIO_PORT, sFLASH_CS_PIN)
#define sFLASH_CS_HIGH() GPIO_SetBits(sFLASH_CS_GPIO_PORT, sFLASH_CS_PIN)
* @brief Sends a byte through the SPI interface and return the byte received
* from the SPI bus.
* @param byte: byte to send.
* @retval The value of the received byte.
uint8_t sFLASH_SendByte(uint8_t byte)
/*!< Loop while DR register in not emplty */
while (SPI_I2S_GetFlagStatus(sFLASH_SPI, SPI_I2S_FLAG_TXE) == RESET);
/*!< Send byte through the SPI1 peripheral */
SPI_I2S_SendData(sFLASH_SPI, byte);
/*!< Wait to receive a byte */
while (SPI_I2S_GetFlagStatus(sFLASH_SPI, SPI_I2S_FLAG_RXNE) == RESET);
/*!< Return the byte read from the SPI bus */
return SPI_I2S_ReceiveData(sFLASH_SPI);
* @brief Reads a block of data from the FLASH.
* @param pBuffer: pointer to the buffer that receives the data read from the FLASH.
* @param ReadAddr: FLASH's internal address to read from.
* @param NumByteToRead: number of bytes to read from the FLASH.
* @retval None
void sFLASH_ReadBuffer(uint8_t* pBuffer, uint32_t ReadAddr, uint16_t NumByteToRead)
/*!< Select the FLASH: Chip Select low */
sFLASH_CS_LOW();
/*!< Send "Read from Memory " instruction */
sFLASH_SendByte(sFLASH_CMD_READ);
/*!< Send ReadAddr high nibble address byte to read from */
sFLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
/*!< Send ReadAddr medium nibble address byte to read from */
sFLASH_SendByte((ReadAddr& 0xFF00) >> 8);
/*!< Send ReadAddr low nibble address byte to read from */
sFLASH_SendByte(ReadAddr & 0xFF);
while (NumByteToRead--) /*!< while there is data to be read */
/*!< Read a byte from the FLASH */
*pBuffer = sFLASH_SendByte(sFLASH_DUMMY_BYTE);
/*!< Point to the next location where the byte read will be saved */
pBuffer++;
/*!< Deselect the FLASH: Chip Select high */
sFLASH_CS_HIGH();
我的板子上STM32运行在12MHz, SPI BR=1.5Mbps/0.75Mbps/0.325Mbps/0.1625Mbps,分别用ST的SPI EEPROM和SPI Flash做了测试,都出现了LZ描述的现象。
