STM32USB2个接口描述符的问题
msy2009   2011-2-18 14:48 楼主
                                 在一个接口描述符工作正常,,在这个基础是增加一个接口描述符,HID描述符,Endpoint描述符,就不行了,没法枚举,这是为什么?》
回复评论 (8)
把你改后的描述符贴出来看看
有没有申明是USB复合设备,具有2个借口描述符?
点赞  2011-2-18 16:55
/* USB Configuration Descriptor */
/*   All Descriptors (Configuration, Interface, Endpoint, Class, Vendor */
const u8 ConfigDescriptor[CONFIG_DESC] =
    0x09, /* bLength: Configuation Descriptor size */
    USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
    CONFIG_DESC,
    /* wTotalLength: Bytes returned */
    0x00,
    0x01,// 0x02,         /*bNumInterfaces: 2 interface*/
    0x01,         /*bConfigurationValue: Configuration value*/
    0x00,         /*iConfiguration: Index of string descriptor describing
                                     the configuration*/
    0xe0,         /*bmAttributes: bus powered */
    0x32,         /*MaxPower 100 mA: this current is used for detecting Vbus*/
    /************** Descriptor interface ****************/
    /* 09 */
    0x09,         /*bLength: Interface Descriptor size*/
    USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type*/
    0x00,         /*bInterfaceNumber: Number of Interface*/
    0x00,         /*bAlternateSetting: Alternate setting*/
    0x02,         /*bNumEndpoints*/
    0x03,         /*bInterfaceClass: HID*/
    0x00,         /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
    0x02,         /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
    0,            /*iInterface: Index of string descriptor*/
    /******************** Descriptor of HID ********************/
    /* 18 */
    0x09,         /*bLength: HID Descriptor size*/
    HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/
    0x10,         /*bcdHID: HID Class Spec release number*/
    0x01,
    0x00,         /*bCountryCode: Hardware target country*/
    0x01,         /*bNumDescriptors: Number of HID class descriptors to follow*/
    0x22,         /*bDescriptorType*/
    REPORT_DESC ,// 0x0f,         /*wItemLength: Total length of Report descriptor*/
    0, //0x01,         //报告描述符长度,0x010f ,271 bytes
    /****************** Endpoint 1 Descriptor************/
    /* 27 */
    0x07,           //bLength: Endpoint Descriptor size*/
    USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:*/
    0x81,          //bEndpointAddress: Endpoint 1 Address (IN)*/
    0x03,          //bmAttributes: Interrupt endpoint*/
    0x40,          //wMaxPacketSiz e: 64 Byte max */
    0x00,
    0x01,          //bInterval: Polling Interval (1 ms)*/
  /**********************Endpoint 1 Descriptor***********************/
    0x07,         // bLength: Endpoint Descriptor size
    USB_ENDPOINT_DESCRIPTOR_TYPE,        // bDescriptorType:
    0x01,        // bEndpointAddress: Endpoint Address (OUT)
    0x03,        // bmAttributes: Interrupt endpoint
    0x40,        // wMaxPacketSize: 64 Bytes max
    0x00,
    0x01,        // bInterval: Polling Interval (1 ms)
这个添加的配置描述符 , 增加下面这些,枚举就失败了
  /* //==================2 接口描述符======================
    0x09, //接口描述符长度
    0x04, //接口描述符
    0x01, //接口编号从1开始
    0x00, //备用编号
    0x02, //该接口使用的端点数
    0x03, //接口使用的类,0x03 是HID
    0x00, //no boot
    0x00, //keyboard
    0x00, //接口字符串的Index
    //===================2 HID描述符========================
    0x09, //HID 描述符 长度
    0x21, //HID 描述符
    0x10, //版本
    0x01,
    0x00, //
    0x01, //
    0x22, //type
    0x41, //报告描述符的长度
    0x00,
   //======================2 端点描述符===================
    0x07, //端点描述符长度
    0x05, //端点描述符
    0x82, //输入端点地址
    0x03, //interrupt
    0x40, //字节数目
    0x00, //
    0x01, //查询时间
    0x07, //端点描述符长度
    0x05, //端点描述符
    0x02, //输出端点地址
    0x03,//interrupt
    0x40, //字节数目
    0x00,
    0x01, //查询时间
点赞  2011-2-19 09:26
                                 有没有人知道哦!
点赞  2011-2-19 14:58
                                 寂寞的问题,寂寞的很
点赞  2011-3-14 14:29
                                 这里高手如云,放心了
点赞  2011-3-14 15:38
描述符没看出问题
我猜最有可能的问题是
你有没有根据接口号上传第二个接口的REPORT描述符?
点赞  2011-3-14 17:03
                                 在枚举时,上传了,
点赞  2011-3-15 11:43
                                 PC就没有读配置描述符了
点赞  2011-3-15 11:43
    写回复
