2812FLASH烧写时出现以下提示,请指教
bayasina   2009-3-26 06:06 楼主
烧写完成后出现:
This program contains initialized RAM data.
It may run successfully under Code Composer Studio
but not as a standalone system because of this. If
your Flash program requires initialized data in RAM,
you will need to write Flash code to initialize RAM memory
未烧写从RAM运行时一切正常,烧写成功后出现以上提示,而且断电、上电从FLASH程序运行后好像一直在定时器中断中运行(定时器中断是主要算法程序),不响应其他程序。
回复评论 (1)
谢谢LS
我的数据定义全在RAM中,要改为定义在FLASH中吗?
点赞  2009-3-26 23:44
    写回复
