我想把ucos移植去2812,但是在烧写中遇到了一些问题,这个问题我在论坛见过,不过不清楚具体是怎样解决的~
下面是遇到的状况:
使用ti的烧写插件烧写FLASH时出现以下提示:
Code Composer could not locate:
FlashAPIInterface.c
Would you like to browse for it?
Do not ask me again.
program的时候出现
no section were found that map to flash
然后
Warning: ...... if your Flash program requires initialized
data in RAM,you will need to write Flash code to initialize RAM.
还有在烧写完成后会出现下面的警告:
Warning: This program contains initialized RAM data.
It may run successfully under Code Composer Studio
but not as a standalone system because of this. If
your Flash program requires initialized data in RAM,
you will need to write Flash code to initialize RAM memory.
但是显示成功。
另外在烧写完成退出ccs时出现红色错误对话框:
Can\'t Remove Breakpoint:
Error 0x0000 0008/-2044
Error during : Break Point,
No breakpoint at 0x0000 906C
是什么原因,应该怎么解决呢?
盼各位前辈指教~
换了.cmd文件后出现新问题:
Load failed. a section of your program falls into a memery region
that is not writable. Check your linker configuration and/or memery map.
之前用的.cmd:EzDSP_RAM_lnk.cmd
MEMORY
PAGE 0 :
/* SARAM H0 is split between PAGE 0 and PAGE 1 */
PRAMH0 : origin = 0x3F8000, length = 0x001000
/* This memory block loaded with the reset vector only if
booting from XINTF Zone 7. Otherwise reset vector is
fetched from boot ROM. See .reset section below */
RESET : origin = 0x3FFFC0, length = 0x000002
PAGE 1 :
/* SARAM */
/* RAMM0 : origin = 0x000000, length = 0x000400 */
RAMM1 : origin = 0x000400, length = 0x000400
MULSTACK : origin = 0x000100, length = 0x000200
MAINSTACK: origin = 0x000300, length = 0x000080
IDLESTACK: origin = 0x000380, length = 0x000080
/* Peripheral Frame 0: */
DEV_EMU : origin = 0x000880, length = 0x000180
FLASH_REGS : origin = 0x000A80, length = 0x000060
CSM : origin = 0x000AE0, length = 0x000010
XINTF : origin = 0x000B20, length = 0x000020
CPU_TIMER0 : origin = 0x000C00, length = 0x000008
CPU_TIMER1 : origin = 0x000C08, length = 0x000008
CPU_TIMER2 : origin = 0x000C10, length = 0x000008
PIE_CTRL : origin = 0x000CE0, length = 0x000020
PIE_VECT : origin = 0x000D00, length = 0x000100
/* Peripheral Frame 1: */
ECAN_A : origin = 0x006000, length = 0x000100
ECAN_AMBOX : origin = 0x006100, length = 0x000100
/* Peripheral Frame 2: */
SYSTEM : origin = 0x007010, length = 0x000020
SPI_A : origin = 0x007040, length = 0x000010
SCI_A : origin = 0x007050, length = 0x000010
XINTRUPT : origin = 0x007070, length = 0x000010
GPIOMUX : origin = 0x0070C0, length = 0x000020
GPIODAT : origin = 0x0070E0, length = 0x000020
ADC : origin = 0x007100, length = 0x000020
EV_A : origin = 0x007400, length = 0x000040
EV_B : origin = 0x007500, length = 0x000040
SPI_B : origin = 0x007740, length = 0x000010
SCI_B : origin = 0x007750, length = 0x000010
MCBSP_A : origin = 0x007800, length = 0x000040
/* CSM Password Locations */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008
DRAMH0 : origin = 0x3f9000, length = 0x001000
SECTIONS
/* Allocate program areas: */
/* Setup for \"boot to H0\" mode:
The codestart section (found in CodeStartBranch.asm)
re-directs execution to the start of user code.
Place this section or the .text section at the
start of H0 */
codestart : > PRAMH0, PAGE = 0
.text : > PRAMH0, PAGE = 0
.cinit : > PRAMH0, PAGE = 0
ramfuncs : > PRAMH0, PAGE = 0, TYPE = DSECT /* not used when only using RAM */
/* Allocate data areas: */
.stack : > RAMM1, PAGE = 1
.bss : > DRAMH0, PAGE = 1
.ebss : > DRAMH0, PAGE = 1
.const : > DRAMH0, PAGE = 1
.econst : > DRAMH0, PAGE = 1
.sysmem : > DRAMH0, PAGE = 1
/* .reset indicates the start of _c_int00 for C Code.
/* When using the boot ROM this section is not needed.
/* Thus, the default type is set to DESECT */
.reset : > RESET, PAGE = 0, TYPE = DSECT
/* Allocate Peripheral Frame 0 Register Structures: */
DevEmuRegsFile : > DEV_EMU, PAGE = 1
FlashRegsFile : > FLASH_REGS, PAGE = 1
CsmRegsFile : > CSM, PAGE = 1
XintfRegsFile : > XINTF, PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
/* CPU_TIMER1 and CPU_TIMER2 are reserved for DSP BIOS
and RTOS use. Therefore these sections are not
allocated in these examples
CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
PieVectTable : > PIE_VECT, PAGE = 1
/* Allocate Peripheral Frame 2 Register Structures: */
ECanaRegsFile : > ECAN_A, PAGE = 1
ECanaMboxesFile : > ECAN_AMBOX PAGE = 1
/* Allocate Peripheral Frame 1 Register Structures: */
SysCtrlRegsFile : > SYSTEM, PAGE = 1
SpiaRegsFile : > SPI_A, PAGE = 1
SciaRegsFile : > SCI_A, PAGE = 1
XIntruptRegsFile : > XINTRUPT, PAGE = 1
GpioMuxRegsFile : > GPIOMUX, PAGE = 1
GpioDataRegsFile : > GPIODAT PAGE = 1
AdcRegsFile : > ADC, PAGE = 1
EvaRegsFile : > EV_A, PAGE = 1
EvbRegsFile : > EV_B, PAGE = 1
ScibRegsFile : > SCI_B, PAGE = 1
McbspaRegsFile : > MCBSP_A, PAGE = 1
CsmPwlFile : > CSM_PWL, PAGE = 1
MulStackFile : > MULSTACK, PAGE = 1
MainStackFile : > MAINSTACK, PAGE = 1
IdleStackFile : > IDLESTACK, PAGE = 1
后来换用的是:F2812.cmd
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
ZONE0 : origin = 0x002000, length = 0x002000 /* XINTF zone 0 */
ZONE1 : origin = 0x004000, length = 0x002000 /* XINTF zone 1 */
RAML0 : origin = 0x008000, length = 0x001000 /* on-chip RAM block L0 */
ZONE2 : origin = 0x080000, length = 0x080000 /* XINTF zone 2 */
ZONE6 : origin = 0x100000, length = 0x080000 /* XINTF zone 6 */
OTP : origin = 0x3D7800, length = 0x000800 /* on-chip OTP */
FLASHJ : origin = 0x3D8000, length = 0x002000 /* on-chip FLASH */
FLASHI : origin = 0x3DA000, length = 0x002000 /* on-chip FLASH */
FLASHH : origin = 0x3DC000, length = 0x004000 /* on-chip FLASH */
FLASHG : origin = 0x3E0000, length = 0x004000 /* on-chip FLASH */
FLASHF : origin = 0x3E4000, length = 0x004000 /* on-chip FLASH */
FLASHE : origin = 0x3E8000, length = 0x004000 /* on-chip FLASH */
FLASHD : origin = 0x3EC000, length = 0x004000 /* on-chip FLASH */
FLASHC : origin = 0x3F0000, length = 0x004000 /* on-chip FLASH */
FLASHA : origin = 0x3F6000, length = 0x001FF6 /* on-chip FLASH */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for \"boot to Flash\" bootloader mode. */
/* ZONE7 : origin = 0x3FC000, length = 0x003FC0 /* XINTF zone 7 available if MP/MCn=1 */
ROM : origin = 0x3FF000, length = 0x000FC0 /* Boot ROM available if MP/MCn=0 */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
/* Registers remain on PAGE1 */
RAMM0 : origin = 0x000000, length = 0x000400 /* on-chip RAM block M0 */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
DEV_EMU : origin = 0x000880, length = 0x000180 /* Device emulation registers */
FLASH_REGS : origin = 0x000A80, length = 0x000060 /* FLASH registers */
CSM : origin = 0x000AE0, length = 0x000010 /* Code security module registers */
XINTF : origin = 0x000B20, length = 0x000020 /* External interface registers */
CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers (CPU Timer1 and Timer2 are reserved for BIOS)*/
PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */
PIE_VECT : origin = 0x000D00, length = 0x000100 /* PIE vector table */
ECAN_A : origin = 0x006000, length = 0x000100 /* eCAN registers */
ECAN_AMBOX : origin = 0x006100, length = 0x000100 /* eCAN mailboxes */
SYSTEM : origin = 0x007010, length = 0x000020 /* System control registers */
SPI_A : origin = 0x007040, length = 0x000010 /* SPI registers */
SCI_A : origin = 0x007050, length = 0x000010 /* SCI-A registers */
XINTRUPT : origin = 0x007070, length = 0x000010 /* External interrupt registers */
GPIOMUX : origin = 0x0070C0, length = 0x000020 /* GPIO mux registers */
GPIODAT : origin = 0x0070E0, length = 0x000020 /* GPIO data registers */
ADC : origin = 0x007100, length = 0x000020 /* ADC registers */
EV_A : origin = 0x007400, length = 0x000040 /* Event Manager A registers */
EV_B : origin = 0x007500, length = 0x000040 /* Event Manager B registers */
SCI_B : origin = 0x007750, length = 0x000010 /* SCI-B registers */
MCBSP_A : origin = 0x007800, length = 0x000040 /* McBSP registers */
RAML1 : origin = 0x009000, length = 0x001000 /* on-chip RAM block L1 */
FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* CSM password locations in FLASHA */
RAMH0 : origin = 0x3F8000, length = 0x002000 /* on-chip RAM block H0 */
/* Allocate sections to memory blocks.
codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
execution when booting to flash
ramfuncs user defined section to store functions that will be copied from Flash into RAM
SECTIONS
.cinit : > FLASHA PAGE = 0
.text : > FLASHA PAGE = 0
codestart : > BEGIN PAGE = 0
ramfuncs : LOAD = FLASHD, RUN = RAML0, PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM0 PAGE = 1
.bss : > RAML1 PAGE = 1
.ebss : > RAML1 PAGE = 1
.sysmem : > RAMH0 PAGE = 1
.esysmem : > RAMH0 PAGE = 1
/* Initalized sections go in Flash */
.const : > FLASHB PAGE = 1
.econst : > FLASHB PAGE = 1
/* Allocate IQ math areas: */
IQmath : > FLASHC PAGE = 0 /* Math Code */
IQmathTables : > ROM PAGE = 0, TYPE = NOLOAD /* Math Tables In ROM */
/* When using the boot ROM this section and the CPU vector
/* table is not needed. Thus the default type is set to
/* DESECT */
vectors : > VECTORS PAGE = 0, TYPE = DSECT
/* The following allocations are required for the DSP28 Header file
examples. Each allocation maps a structure defined in the DSP28
header files to the memory location of those registers.
DevEmuRegsFile : > DEV_EMU PAGE = 1
FlashRegsFile : > FLASH_REGS PAGE = 1
CsmRegsFile : > CSM PAGE = 1
XintfRegsFile : > XINTF PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0 PAGE = 1
PieCtrlRegsFile : > PIE_CTRL PAGE = 1
PieVectTable : > PIE_VECT PAGE = 1
ECanaRegsFile : > ECAN_A PAGE = 1
SysCtrlRegsFile : > SYSTEM PAGE = 1
SpiaRegsFile : > SPI_A PAGE = 1
SciaRegsFile : > SCI_A PAGE = 1
XIntruptRegsFile : > XINTRUPT PAGE = 1
GpioMuxRegsFile : > GPIOMUX PAGE = 1
AdcRegsFile : > ADC PAGE = 1
EvaRegsFile : > EV_A PAGE = 1
EvbRegsFile : > EV_B PAGE = 1
ScibRegsFile : > SCI_B PAGE = 1
McbspaRegsFile : > MCBSP_A PAGE = 1
CsmPwlFile : > CSM_PWL PAGE = 1
请指教~!!
