烧片子出现这样的话是什么意思呢?
liuyanying   2008-4-28 14:28 楼主
Can\'t Set Breakpoint: Cannot set/verify breakpoint at 0x2CA
Breakpoint Manager: An error was encountered attempting to set a breakpoint used
for end of program detection.
还有一句是:
The address specified in the COFF file is out of range(Flash Memory)
我的cmd文件是这样的:
-stack 30
MEMORY
  PAGE 0:    /* Program Memory */
    VECS:           org=00000h,   len=00040h   /* internal FLASH */
    PROG:           org=00044h,   len=07000h   /* internal FLASH */
  PAGE 1:    /* Data Memory */
    B2:             org=00060h,   len=00020h   /* internal DARAM */
    B0:             org=00200h,   len=00100h   /* internal DARAM */
    B1:             org=00300h,   len=00100h   /* internal DARAM */
    SARAM:          org=00800h,   len=00800h   /* internal SARAM */
SECTIONS
    .vectors:  >    VECS          PAGE 0
       .text:  >    PROG          PAGE 0
    .fftdata:  >        B0                          PAGE 1
   .adsample:  >        B1                          PAGE 1
      .stack:  >    B2                PAGE 1
        .bss:  >    SARAM         PAGE 1
回复评论 (3)
PROG的长度设置有问题,你的内部flash根本就没有0x7000,建议改为0x4000看一下了
点赞  2008-5-2 05:15
问题终于找到了.原来是外接电源供电不够的问题...后来换了一个12V的变压器都搞定了.
点赞  2008-5-8 16:17
供电电流不足的情况,我也遇到过。当时现象就是仿真一点问题没有,一旦烧写FLASH就死在那里
哈哈,看来设计板子时还真要把所需电流大概算一下,选用合适电源,宁大勿小
点赞  2008-5-9 04:14
    写回复
