错误提示如下:
Error connecting to the target:
Error 0x80000240/-291
Fatal Error during: Initialization, OCS,
This error was generated by TI\'s USCIF driver.
SC_ERR_TST_MEASURE <-291>
The built-in scan-path length measurement has failed. This indicates
that the JTAG controller cannot reliably communicate with
the target DSP\'s and micro-controllers at that frequency.
Try specifying the scan-path lengths in the board configuration
file because the built-in scan-path reliability tests cannot be
performed without knowledge of the scan-path length.
Sequence ID: 0
Error Code: -291
Error Class: 0x80000240
Board Name: F2812 XDS560 Emulator
Cpu Name: CPU_1
Abort: Close Code Composer Studio.
Retry: Try to connect to the target again.
Cancel: Remain disconnected from the target
Diagnostic: Run diagnostic utility.
谢谢!
楼上的用XDS560仿真器调试吗?一般不会出现这样的问题,建议先用标准的DSP板卡连接试试看。
[ 本贴由 edward 于 2008-2-25 11:42 AM 最后编辑 ]
我也有相同的问题,我的DSP上电后,jtag的tms脚的电平不正常,其他电平都正常,而且dsp的时钟输出也是正确的,我怀疑焊板子的时候这个引脚虚焊了不知楼主的怎么样?
这块就行了
又新焊了一块,这次jtag各引脚的上电电平完全正确,接仿真器也通了
我也遇到这样的问题,望各位高手指点,联系QQ7112376
