[讨论] 8051的汇编控制指令
fighting   2006-7-17 10:34 楼主
8051的汇编控制指令
[ 打印 ] [ 返回 ]
1.Arithmetic operations:
Mnemonic Byte Cyc
ADD A,@Ri 1 1
ADD A,Rn 1 1
ADD A,direct 2 1
ADD A,#data 2 1
ADDC A,@Ri 1 1
ADDC A,Rn 1 1
ADDC A,direct 2 1
ADDC A,#data 2 1
SUBB A,@Ri 1 1
SUBB A,Rn 1 1
SUBB A,direct 2 1
SUBB A,#data 2 1
INC A 1 1
INC @Ri 1 1
INC Rn 1 1
INC DPTR 1 1
INC direct 2 1
INC direct 2 1
DEC A 1 1
DEC @Ri 1 1
DEC Rn 1 1
DEC direct 2 1
MUL AB 1 4
DIV AB 1 4
DA A 1 1
2.Logical opreations:
ANL A,@Ri 1 1
XRL A,@Ri 1 1
ANL A,Rn 1 1
XRL A,Rn 1 1
ANL A,direct 2 1
XRL A,direct 2 1
ANL A,#data 2 1
XRL A,#data 2 1
ANL direct,A 2 1
XRL direct,A 2 1
ANL direct,#data 3 2
XRL direct,#data 3 2
ORL A,@Ri 1 1
CLR A 1 1
ORL A,Rn 1 1
CPL A 1 1
ORL A,direct 2 1
RL A 1 1
ORL A,#data 2 1
RLC A 1 1
ORL direct,A 2 1
RR A 1 1
ORL direct,#data 3 2
RRC A 1 1
SWAP A 1 1
3.Data transfer:
Mnemonic Byte Cyc
MOV A,@Ri 1 1
MOV DPTR,#data16 3 2
MOV A,Rn 1 1
MOVC A,@A+DPTR 1 2
MOV A,direct 2 1
MOVC A,@A+PC 1 2
MOV A,#data 2 1
MOVX A,@Ri 1 2
MOV @Ri,A 1 1
MOVX A,@DPTR 1 2
MOV @Ri,direct 2 2
MOVX @Ri,A 1 2
MOV @Ri,#data 2 1
MOVX @DPTR,A 1 2
MOV Rn,A 1 1
PUSH direct 2 2
MOV Rn,direct 2 2
POP direct 2 2
MOV Rn,#data 2 1
XCH A,@Ri 1 1
MOV direct,A 2 1
XCH A,Rn 1 1
MOV direct,@Ri 2 2
XCH A,direct 2 1
MOV direct,Rn 2 2
XCHD A,@Ri 1 1
MOV direct,direct 3 2
MOV direct,#data 3 2
4.Boolean variable manipulation:
Mnemonic Byte Cyc
CLR C 1 1
ANL C,bit 2 2
SETB C 1 1
ANL C,/bit 2 2
CPL C 1 1
ORL C,bit 2 2
CLR bit 2 1
ORL C,/bit 2 2
SETB bit 2 1
MOV C,bit 2 1
CPL bit 2 1
MOV bit,C 2 2
5.Program and machine control:
Mnemonic Byte Cyc
NOP 1 1
JZ rel 2 2
RET 1 2
JNZ rel 2 2
RETI 1 2
JC rel 2 2
ACALL addr11 2 2
JNC rel 2 2
AJMP addr11 2 2
JB bit,rel 3 2
LCALL addr16 3 2
JNB bit,rel 3 2
LJMP addr16 3 2
JBC bit,rel 3 2
SJMP rel 2 2
CJNE A,direct,rel 3 2
JMP @A+DPTR 1 2
CJNE A,#data,rel 3 2
DJNZ Rn,rel 2 2
CJNE @Ri,#data,rel 3 2
DJNZ direct,rel 3 2
回复评论 (1)
点赞  2009-5-1 15:19
    写回复
