我正在学习msp430的串口操作。
下载了几个例子程序,但是它们都是用 Tx/Rx 来控制的。
而我的硬件设备用了485模块,是RS485,而不是RS232,因此没有 Tx/Rx, 没法调试。
谁有不需要 Tx/Rx控制的串口程序源代码吗? 谢谢。
不太明白你的意思。
你是不是做485通信啊?485在处理通信的时候要切换RX和TX,因为485是半双工的,不能同时收发。
你如果说是不用430 的串口自己另外设计的话可以试试用普通I/O口来模拟串口通信,在速度比较低的情况下还是不错的。
谢谢tzynt。
我是做485通信。 硬件是现成的,用的是uart1。 硬件是肯定没问题的,因为别人能用。但是我们只搞到了硬件,却没有拿到别人的源程序。
我试了好几个例子程序,都没法收发数据。
谁有好的例子程序吗?
谢谢。
参考下面的例子:
// MSP-FET430X110 Demo - Timer_A UART Ultra-low Power 2400 Echo, 32kHz ACLK
// Description: Use timer_A CCR0 hardware output modes and SCCI data latch to
// to implement UART function @ 2400 baud. Software does not directly read and
// write to RX and TX pins, instead proper use of output modes and SCCI data
// latch are demonstrated. Use of these hardware features eliminates ISR
// latency effects as hardware insures that output and input bit latching and
// timing are perfectly synchronised with timer_A regardless of other
// software activity. In the Mainloop the UART function readies the UART to
// receive one character and waits in LPM3 with all activity interrupt driven.
// After a character has been received, the UART receive function forces exit
// from LPM3 in the Mainloop which echo's back the received character.
// ACLK = TACLK = LFXT1 = 32768, MCLK = SMCLK = DCO ~ 800k
// //*An external watch crystal is required on XIN XOUT for ACLK*//
// MSP430F1121
// /|\| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | CCI0A/TXD/P1.1|-------->
// | | 2400 8N1
// | CCI0B/RXD/P2.2|<--------
#define RXD 0x04 // RXD on P2.2
#define TXD 0x02 // TXD on P1.1
// Conditions for 2400 Baud SW UART, ACLK = 32768
#define Bitime_5 0x06 // ~ 0.5 bit length + small adjustment
#define Bitime 0x0E // 427us bit length ~ 2341 baud
unsigned int RXTXData;
unsigned char BitCnt;
void TX_Byte (void);
void RX_Ready (void);
// M.Buccini
// Texas Instruments, Inc
// September 2003
// Built with IAR Embedded Workbench Version: 1.26B
// January 2004
// Updated for IAR Embedded Workbench Version: 2.21B
#include <msp430x11x1.h>
void main (void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
CCTL0 = OUT; // TXD Idle as Mark
TACTL = TASSEL_1 + MC_2; // ACLK, continuous mode
P1SEL = TXD; // P1.1/TA0 for TXD function
P1DIR = TXD; // TXD output on P1
P2SEL = RXD; // P2.2/TA0 as RXD input
// Mainloop
for (;;)
RX_Ready(); // UART ready to RX one Byte
_BIS_SR(LPM3_bits + GIE); // Enter LPM3 w/ interr until char RXed
TX_Byte(); // TX Back RXed Byte Received
// Function Transmits Character from RXTXData Buffer
void TX_Byte (void)
BitCnt = 0xA; // Load Bit counter, 8data + ST/SP
while (CCR0 != TAR) // Prevent async capture
CCR0 = TAR; // Current state of TA counter
CCR0 += Bitime; // Some time till first bit
RXTXData |= 0x100; // Add mark stop bit to RXTXData
RXTXData = RXTXData << 1; // Add space start bit
CCTL0 = OUTMOD0 + CCIE; // TXD = mark = idle
while ( CCTL0 & CCIE ); // Wait for TX completion
// Function Readies UART to Receive Character into RXTXData Buffer
BitCnt = 0x8; // Load Bit counter
CCTL0 = SCS + CCIS0 + OUTMOD0 + CM1 + CAP + CCIE; // Sync, Neg Edge, Cap
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
CCR0 += Bitime; // Add Offset to CCR0
// RX
if (CCTL0 & CCIS0) // RX on CCI0B?
if( CCTL0 & CAP ) // Capture mode = start bit edge
CCTL0 &= ~ CAP; // Switch from capture to compare mode
CCR0 += Bitime_5;
else
RXTXData = RXTXData >> 1;
if (CCTL0 & SCCI) // Get bit waiting in receive latch
RXTXData |= 0x80;
BitCnt --; // All bits RXed?
if ( BitCnt == 0)
//>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
CCTL0 &= ~ CCIE; // All bits RXed, disa××e interrupt
_BIC_SR_IRQ(LPM3_bits); // Clear LPM3 bits from 0(SR)
// TX
else
if ( BitCnt == 0)
CCTL0 &= ~ CCIE; // All bits TXed, disa××e interrupt
else
CCTL0 |= OUTMOD2; // TX Space
if (RXTXData & 0x01)
CCTL0 &= ~ OUTMOD2; // TX Mark
BitCnt --;
