// MSP-FET430P140 Demo - USART0 UART 115200 Echo ISR, HF XTAL ACLK
// Description; Echo a received character, RX ISR used. Normal mode is LPM0,
// USART0 RX interrupt triggers TX Echo.
// ACLK = MCLK = UCLK0 = LFXT1 = 8MHz
// Baud rate divider with 8Mhz XTAL = 8000000/115200 = 0069 (0045h)
// //*USART0 interrupt flags are in different SFR's from other MSP430's//
// //*An external 8Mhz XTAL on XIN XOUT is required for ACLK*//
// MSP430F149
// /|\| XIN|-
// | | | 8MHz
// --|RST XOUT|-
// | P3.4|------------>
// | | 115200 - 8N1
// | P3.5|<------------
// M. Buccini
// Texas Instruments, Inc
// February 2002
// Built with IAR Embedded Workbench Version: 1.25A
#include <msp430x14x.h>
void main(void)
unsigned int i,j,k;
char Data[6]="MSP430";
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 |= XTS; // ACLK = LFXT1 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (k = 0xFF; k > 0; k--); // Time for flag to set
while ((IFG1 & OFIFG) ==OFIFG); // OSCFault flag still set?
BCSCTL2 |= SELM1+SELM0; // MCLK = LFXT1 (safe)
UCTL0 = CHAR; // 8-bit character
UTCTL0 = SSEL0; // UCLK = ACLK
UBR00 = 0x45; // 8MHz 115200
UBR10 = 0x00; // 8MHz 115200
UMCTL0 = 0x00; // 8MHz 115200 modulation
ME1 |= UTXE0 + URXE0; // Ena××e USART0 TXD/RXD
// IE1 |= URXIE0; // Ena××e USART0 RX interrupt
P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD
P3DIR |= 0x10; // P3.4 output direction
// _EINT(); // Ena××e interrupts
while(1)
TXBUF0=0xFF;
while((UTCTL0&0x01)==0);
for(j=0;j<=6;j++)
TXBUF0=Data[j];
P1DIR |=0x02;
P1OUT ^=0x02;
i=50000;
do(i--);
while(i!=0);
for (;;)
_BIS_SR(CPUOFF); // Enter LPM0
_NOP(); // Required only for C-spy
interrupt[UART0RX_VECTOR] void usart0_rx (void)
while ((IFG1 & UTXIFG0) == 0); // USART0 TX buffer ready?
TXBUF0 = RXBUF0; // RXBUF0 to TXBUF0
运行该例程 执行到while ((IFG1 & OFIFG) ==OFIFG); // OSCFault flag still set?
就运行不下去了!在此反复循环!不知道是何原因!请各位大侠指导!
查看8M晶体旁的两个电容是否接好,且为15--22pf; VCC是否为3.6v?
如果是8M在XT1上,不能工作,应将晶体接到XT2上。
XT1最好接低频,xt2接高频,xt1接高频好像还是可以的
