【求助】请问如何用Timer_A来实现IIC的时序?
妖刀村正   2006-8-12 19:47 楼主
看了很多IIC的程序,都是用延时来实现IIC的时序,请问怎样用Timer_A来实现呢?怎样读写?
回复评论 (7)
这个一般用不着定时器的,延时就可以了。
void delay_xms(void)
WORD i;
for(i=0;i<800;i++);
_NOP();
void rw_I2C_start(void)
MY_PXSEL &=~(SCL+SDA+WP);
MY_PXDIR |=(SCL+SDA+WP);
MY_PXOUT &=~WP;
_NOP();
_NOP();
MY_PXOUT |=SDA;
_NOP();
_NOP();
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT &=~SDA;
_NOP();
_NOP();
MY_PXOUT &=~SCL;
void rw_I2C_stop(void)
MY_PXDIR |=SDA;
MY_PXOUT &=~SDA;
_NOP();
_NOP();
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT |=SDA;
BYTE r_I2C_byte(void)
BYTE i,j=0;
MY_PXDIR &=~SDA;
for(i=1;i<=8;i++)
MY_PXOUT |=SCL;
j <<=1;
if ((MY_PXIN&SDA)==SDA) j |=0x01;
MY_PXOUT &=~SCL;
_NOP();
MY_PXDIR |=SDA;
MY_PXOUT |=SDA;
_NOP();
_NOP();
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT &=~SDA;
_NOP();
_NOP();
MY_PXOUT &=~SCL;
return j;
WORD r_I2C_word(void)
BYTE i;
WORD j=0;
MY_PXDIR &=~SDA;
for(i=1;i<=16;i++)
MY_PXOUT |=SCL;
j <<=1;
MY_PXOUT &=~SCL;
_NOP();
MY_PXDIR |=SDA;
MY_PXOUT |=SDA;
_NOP();
_NOP();
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT &=~SDA;
_NOP();
_NOP();
MY_PXOUT &=~SCL;
return j;
// 单字节I2C的写入。
void w_I2C_byte( BYTE nByte ) //read or write command (0xAF read; OxAE write)
{ //start + 1010xxx (read or write start)
BYTE i;
MY_PXDIR |=SDA;
for(i=1;i<=8;i++)
if ((nByte&0x80)==0x80) MY_PXOUT |=SDA;
else MY_PXOUT &=~SDA;
nByte <<=1;
_NOP();
_NOP();
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT &=~SCL;
_NOP();
_NOP();
MY_PXDIR &=~SDA;
MY_PXOUT |=SCL;
_NOP();
_NOP();
MY_PXOUT &=~SCL;
// 设置E2PROM口线,使之进入低功耗。
void ee_port_set(void)
MY_PXDIR |=WP+SCL+SDA;
MY_PXOUT |=WP+SCL+SDA;
// [*Ram_Addr]--
// [I2C_Addr1]-- I2C的器件地址
// [I2C_Addr2]-- I2C的内部读写地址
// [nLen]-- 读写地址的字节数
void r_I2C_bytes( BYTE *Ram_Addr, BYTE I2C_Addr1, WORD I2C_Addr2, BYTE nLen )
rw_I2C_start();
w_I2C_byte( I2C_Addr1 );
// w_I2C_byte( I2C_Addr2>>8 ); // address 0 >=24C64
w_I2C_byte( I2C_Addr2&0xFF ); // address 1
for( ; nLen>0; nLen-- )
rw_I2C_start(); // Current Address Read
w_I2C_byte( I2C_Addr1|1 );
(*Ram_Addr) = r_I2C_byte();
Ram_Addr++;
rw_I2C_stop();
ee_port_set();
// [*Ram_Addr]--
void w_I2C_bytes( BYTE *Ram_Addr, BYTE I2C_Addr1, WORD I2C_Addr2, BYTE nLen )
rw_I2C_start();
w_I2C_byte( I2C_Addr1 ); // control byte
w_I2C_byte( *Ram_Addr );
Ram_Addr++;
rw_I2C_stop();
delay_xms();
ee_port_set();
void r_I2C_words( WORD *Ram_Addr, BYTE I2C_Addr1, WORD I2C_Addr2 )
rw_I2C_start();
(*Ram_Addr) = r_I2C_word();
rw_I2C_stop();
ee_port_set();
点赞  2006-8-14 13:09
我也用延时做了一个程序,但有朋友说用延时占用了太多CPU资源,在延时时CPU就做不了其他的了,建议我用定时器来做,我是初学MSP430单片机的,所以有很多不懂,不知道该怎样用定时器来做,编了一段程序,但时序老是不对,要不就是SCL线出来一周期性的PWM波,不知道该怎样传输数据了,还请版主指教。
点赞  2006-8-14 13:59
提示: 作者被禁止或删除 内容自动屏蔽
点赞  2006-8-14 16:08
又学东西了!
点赞  2006-8-14 23:00
将延时改成定时器定时,不用中断吗,那这样岂不是同延时差不多,也没有节约CPU啊?请多多指教,非常感谢!
点赞  2006-8-15 15:52
用定时器用中断方式不要用查询标志位的方式就行了,这样CPU就不占用了。
点赞  2006-8-15 16:10
多谢各位大力帮忙了,我再试试看。
点赞  2006-8-15 16:31
    写回复
