BCSCTl1和BCSCTL2的问题。
suo618   2005-10-9 15:19 楼主
我使用MSP430F449在IAR中写入
BCSCTL2|=BIT7;
BCSCTL2&=~BIT6; //SELM.1=1,SELM.0=0;MCLK时钟源为TX2CLK
编译时报错:
Error[Pe020]: identifier "BCSCTL1" is undefined
Error[Pe020]: identifier "BCSCTL2" is undefined
这是怎么回事?
回复评论 (4)
您用的1XXX系列的设置方式,4XXX的设置供参考:
#include "msp430x44x.h"
void main(void)
unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // stop watchdog timer
FLL_CTL0 |= XCAP18PF; // set load capacitance for 32k xtal
FLL_CTL1 = FLL_CTL1 & ~XT2OFF; // clear bit = high freq xtal on
do // loop until flag is clear
FLL_CTL0 = FLL_CTL0 & ~XT2OF; // clear high freq oscillator fault flag
for (i = 50000; i; i--); // delay for crystal to start and FLL to lock
while (FLL_CTL0 & XT2OF); // test high freq oscillator fault flag
// if flag remained clear then -
FLL_CTL1 = SELS; // switch SMCLK = HF xtal
P1DIR = 0x32; // P1.1, P1.4 & P1.5 to outputs
P1SEL = 0x32; // P1.1, P1.4 & P1.5 functions to output
// MCLK, SMCLK & ACLK
while(1); // loop in place
相关资料可以登陆 www.lierda.com 网站的“资料库”里搜索“C语言”或“汇编语言”查询。
点赞  2005-10-9 15:29
在449中BCSCTL2的c语言的保留字不是这样定义的,你查一下有关的定义.
点赞  2005-10-10 09:00
碰到了跟楼主一样的问题,不知有人是否解决?
点赞  2008-11-13 15:59
449里没有DCOCTL   BCSCTL1 这个寄存器  看下用户手册 一目了然
点赞  2008-11-15 00:09
    写回复
