[讨论] 飞机游戏程序
护花使者   2007-4-5 10:26 楼主
#ifndef AT89CX051_HEADER_FILE
#define AT89CX051_HEADER_FILE 1
//Byte 寄存器
sfr SP      = 0x81;
sfr DPL     = 0x82;
sfr DPH     = 0x83;
sfr PCON    = 0x87;
sfr TCON    = 0x88;
sfr TMOD    = 0x89;
sfr TL0     = 0x8A;
sfr TL1     = 0x8B;
sfr TH0     = 0x8C;
sfr TH1     = 0x8D;
sfr P1      = 0x90;
sfr SCON    = 0x98;
sfr SBUF    = 0x99;
sfr IE      = 0xA8;
sfr P3      = 0xB0;
sfr IP      = 0xB8;
sfr PSW     = 0xD0;
sfr ACC     = 0xE0;
sfr B       = 0xF0;
//PCON
#define IDL_    0x01
#define STOP_   0x02
#define EWT_    0x04
#define EPFW_   0x08
#define WTR_    0x10
#define PFW_    0x20
#define POR_    0x40
#define SMOD_   0x80
//TCON
sbit IT0  = 0x88;
sbit IE0  = 0x89;
sbit IT1  = 0x8A;
sbit IE1  = 0x8B;
sbit TR0  = 0x8C;
sbit TF0  = 0x8D;
sbit TR1  = 0x8E;
sbit TF1  = 0x8F;
//TMOD值
#define T0_M0_   0x01
#define T0_M1_   0x02
#define T0_CT_   0x04
#define T0_GATE_ 0x08
#define T1_M0_   0x10
#define T1_M1_   0x20
#define T1_CT_   0x40
#define T1_GATE_ 0x80
#define T1_MASK_ 0xF0
#define T0_MASK_ 0x0F
//P1
sbit P1_0 = 0x90;
sbit P1_1 = 0x91;
sbit P1_2 = 0x92;
sbit P1_3 = 0x93;
sbit P1_4 = 0x94;
sbit P1_5 = 0x95;
sbit P1_6 = 0x96;
sbit P1_7 = 0x97;
sbit AIN0 = 0x90;                 // + 输入
sbit AIN1 = 0x91;                 //- 输入
//SCON
sbit RI   = 0x98;
sbit TI   = 0x99;
sbit RB8  = 0x9A;
sbit TB8  = 0x9B;
sbit REN  = 0x9C;
sbit SM2  = 0x9D;
sbit SM1  = 0x9E;
sbit SM0  = 0x9F;
//IE
sbit EX0  = 0xA8;         // 开INT0
sbit ET0  = 0xA9;         // 开ET0
sbit EX1  = 0xAA;         // 开INT1
sbit ET1  = 0xAB;         // Timer 1
sbit ES   = 0xAC;         // 开ES
sbit ET2  = 0xAD;         // Timer 2
sbit EA   = 0xAF;         // 关中断
//P3
sbit P3_0 = 0xB0;
sbit P3_1 = 0xB1;
sbit P3_2 = 0xB2;
sbit P3_3 = 0xB3;
sbit P3_4 = 0xB4;
sbit P3_5 = 0xB5;
sbit P3_7 = 0xB7;
sbit RXD  = 0xB0;                // 串行收中断
sbit TXD  = 0xB1;                //串行发中断
sbit INT0 = 0xB2;                 // INT0
sbit INT1 = 0xB3;                 // INT11
sbit T0   = 0xB4;                 // Timer 0
sbit T1   = 0xB5;                 // Timer 1
sbit AOUT = 0xB6;                // 模拟输出
//IP
sbit PX0  = 0xB8;
sbit PT0  = 0xB9;
sbit PX1  = 0xBA;
sbit PT1  = 0xBB;
sbit PS   = 0xBC;
//PSW
sbit P    = 0xD0;
sbit FL   = 0xD1;
sbit OV   = 0xD2;
sbit RS0  = 0xD3;
sbit RS1  = 0xD4;
sbit F0   = 0xD5;
sbit AC   = 0xD6;
sbit CY   = 0xD7;
//中断地址= (Number * 8) + 3
#define IE0_VECTOR 0                    // 0x03 INT0
#define TF0_VECTOR 1                    // 0x0B Timer 0
#define IE1_VECTOR 2                    // 0x13 INT11
#define TF1_VECTOR 3                    // 0x1B Timer 1
#define SIO_VECTOR 4                    // 0x23 串行口
#endif
// io分配:
/* OUTPUT:
 P1.0 ...... 模拟量输入
  P1.1 ...... DA输入比较基准电压
P1.2~7..... R-2R DA电阻网络
P3.7 ...... LED 模拟亮度输出
CPU CLOCK EQU 6M            */
//#pragma src
#include "AT89x051.h"
#include <stdlib.h>
#include<math.h>
#include<intrins.h>
//变量类型标识的宏定义
#define Uchar unsigned char
#define Uint unsigned int
#define Ledlight() (P3 &= 0x7f)
#define Leddark()  (P3 |= 0x80)
sbit P36 = P3^6;            // 比较器内部判断脚
sbit LED = P3^7;            // 一个发光二级管观察亮度变化
// 内部标志位定义
bit less;                 // 比较是否大于 1.小于,0.大于
// 全局变量定义
Uchar timer1,            // 通用延时计数器
 timer2,                // 按键蜂鸣器反应定时器
 adcdata,                // ad转换变量
 pwm1;             // PWM输出比例
// 函数列表
void DelayMs(unsigned int number); // 毫秒延时
void timers0();             // 在定时器中断中做数码管的扫描显示(ct0)
void Initall(void);            // 系统初始化
void timers1(void);            // TC1定时器中断用于扫描显示与键盘
Uchar adcread(void);     // adc转换程序
void main(void)  using 0
 DelayMs(120);
 Initall();
 pwm1 = adcread();
 LED=1;
 while(1)
  pwm1 = adcread();
  timer2=10;
  while (timer2);
// 毫秒延时
 unsigned char temp;
 for(;number!=0;number--)
  for(temp=112;temp!=0;temp--);
//在定时器中断中做LED的PWM输出
void timers0() interrupt 1 using 1
 TH0 = 0xff;
 TL0 = 0xd0;
 timer1--;
 if (timer1==pwm1)LED=0;
 if (timer1==0){
  LED=1;
  timer1=0x40;
  timer2--;
//6位 ADC转换
Uchar adcread(void)
 Uchar i=0x3f,temp=0;
 P36 =1;
 P1 = 3; _nop_();_nop_();       //从零开始
 while ((i--)&& (P36))
  temp += 4;
  P1 = temp|3;
  _nop_();
 temp >>= 2;
 return temp;
//系统初始化
void Initall(void)
 TMOD = 0x11;    // 0001 0001 16进制计数器
 IP = 0x8;            // 0000 1000 t1优先
        IE = 0x8A;    // 1000 1010 t0,t1中断允许
 TCON = 5;        // 0000 0101 外部中断低电平触发
        TR0 = 1;        // 打开定时器中断,IE中已经打开,在明示一下
 TR1 = 0;
        ET0 = 1;
 ET1 = 0;
        P1 = 0xff;
// TC1定时器中断用于扫描显示与键盘(ct1)
void timers1(void) interrupt 3 using 2
_nop_();                     //实验中没有启用
回复评论 (2)
Re: 飞机游戏程序
嘎嘎。。顶一个
呼呼...在校应届大四学生,代做电子类毕业设计(测量类、仪器类、控制类、无线通信类、电子产品类、界面设计类、纯论文类等等,一一俱全)。涉及各种单片机软硬件设计、电路模拟分析、FPGA、CPLD、ARM7/ARM9、LINUX、VB/VC++/QT界面等等。包过。。。欢迎咨询。Tel:13957160506。QQ:273437087
点赞  2007-4-5 10:30
Re: 飞机游戏程序
谢谢支持啊.大家有什么好玩的使劲往上传啊
点赞  2007-4-5 10:34
    写回复
