回复 5楼 wstt 的帖子
谢谢斑竹啊~~~
#include "msp430x16x.h" //使用UART1串口SPI模式控制SD卡存储 端口选择 P5.0/STE=1 P5.1/SIMO=2 P5.2/SOMI=7 P5.3/UCLK=5
#include "string.h"
#include "sca3060spi.h"
#define CS_1 P5OUT|=0x01
#define CS_0 P5OUT&=~0x01
#define SUCCESS 1
#define failed 0
#define cmd0 0
#define cmd1 1
#define cmd8 8
#define cmd55 55
#define acmd41 41
#define cmd9 9
#define cmd16 16
#define cmd24 24
#define cmd17 17
unsigned char response=0;//回应
void open_xt2(void)
BCSCTL1 &= ~XT2OFF;
char n;
do
IFG1 &= ~OFIFG;
for(n=0xee;n>0;n--)
while((IFG1&OFIFG)!=0);
BCSCTL2 |= SELM_2+ SELS+DIVM_3;
void SPI_init(void)
open_xt2();//函数
UCTL1=SWRST;//开启设置
UTCTL1=CKPH+SSEL1+STC;//选择SMCLK
UCTL1|=CHAR+SYNC+MM;//8为数据 SPI模式
UBR01=0x04;//波特率设置
UBR11=0X00;
UMCTL1=0X00;
UCTL1&=~SWRST;//关闭设置
ME2|=USPIE1;//使能SPI
//发送八位字节 同时用于延时八个CLK
char Sendbyte(unsigned char byte)
while((IFG2&UTXIFG1)==0);//等待...直到发送中断标志位置位
TXBUF1=byte;
while((IFG2&URXIFG1)==0);//等待...直到接受缓存数据满 再取回数据
return (RXBUF1);
void Sendcmd(unsigned char cmd,unsigned long data,unsigned char CRC)//cmd 命令字 data 命令指令 CRC 校验位
unsigned char command[6];
int i;
command[0]=(cmd|0x40);
for(i=1;i<5;i++)
command
=(char)(data>>8*(4-i));
command[5]=CRC;
for(i=0;i<6;i++)
Sendbyte(command);
//回应0x00
unsigned char getresponse0()
int i=0;
while(i<10)
response= Sendbyte(0xff);
if(response==0x00)break;
i++;
return (response);
//回应0x01
unsigned char getresponse1()
int i=0;
while(i<10)
response=Sendbyte(0xff);
if(response==0x01)break;
i++;
return (response);
//SD卡初始化
char SD_init(void)
int i;
int time=5;
unsigned char response1=0xff,response2=0xff;
P5SEL|=0X0e;//0000 1110 P5.0.1.2.3选择第二功能
P5DIR|=0X0b; //0000 0111 miso为输入
SPI_init();
CS_1;
do
if(!time)
return (failed);
time--;
for(i=0;i<10;i++)
Sendbyte(0xff);//延时80个CLK
CS_0;
Sendcmd(cmd0,0,0x95);
while(getresponse1()!=0x01);
while((response1!=0x01)||(response2!=0x00))
CS_1;
Sendbyte(0xff);//延时8个CLK
CS_0;
Sendcmd(cmd55,0,0xff);
response1=getresponse1();
CS_1;
Sendbyte(0xff);
CS_0;
Sendcmd(acmd41,0,0xff);
response2=getresponse0();
CS_1;
Sendbyte(0xff);
return (SUCCESS);
//设置数据长度 cmd16
char Set_block_length(unsigned long length)
CS_0;
Sendcmd(cmd16,length,0xff);
while(getresponse0()!=0x00)
SD_init();
CS_0;
CS_1;
Sendbyte(0xff);
return (SUCCESS);
//读取SD卡数据(单块)
char Read_data(unsigned long address,unsigned long length,unsigned char *buffer)
int check;
unsigned long i;
check=Set_block_length(length);
if(check==SUCCESS)
do
Sendbyte(0xff);
CS_0;
Sendcmd(cmd17,address,0xff);
while(getresponse0()!=0x00);
while(Sendbyte(0xff)!=0xfe);
for(i=0;i
buffer=Sendbyte(0xff);
CS_1;
Sendbyte(0xff);
return (*buffer);
//发送命令字
//读取SD卡容量信息,此信息存储在CSD寄存器中 通过发送cmd9来读取
//需要数据为80-84/SD_len 62-73/SD_size 47-49/SD_size_mult
unsigned long Read_SD_size(void)
unsigned int data,i,j,SD_size;
unsigned char SD_len,SD_size_mult;
unsigned long SD_card_size;
do
CS_1;
Sendbyte(0xff);
CS_0;
Sendcmd(cmd9,0,0xff);
do
data=response=Sendbyte(0xff);
while(data!=0xfe);
for(i=0;i<5;i++)//88-127
data=Sendbyte(0xff);
data=Sendbyte(0xff);//80-87
SD_len=data&0x0F;//取出80-83
data=Sendbyte(0xff);//72-79
SD_size=(data&0x03)<<10;//取出72-72位 并放到最高位
data=Sendbyte(0xff);//64-71
SD_size+=data<<2;
data=Sendbyte(0xff);//56-63
SD_size+=data>>6;
data=Sendbyte(0xff);//48-55
SD_size_mult=(data&0x3)<<1;//取出48-49
data=Sendbyte(0xff);//40-47
SD_size_mult+=data>>7;
for(i=0;i<5;i++)
data=Sendbyte(0xff);//0-39
for(i=0;i<4;i++)//延时
Sendbyte(0xff);
CS_0;
//开始计算容量
SD_card_size=SD_size+1;
for(i=2,j=SD_size_mult+2;j>1;j--)
i<<=1;
SD_card_size*=i;
for(i=2,j=SD_len;j>1;j--)
i<<=1;
SD_card_size*=i;
return SD_card_size;
//向SD卡写数据(单块) 写入的地址 数据长度 要写入的数据
unsigned char Write_data(unsigned long address,unsigned long length ,unsigned char *buffer)
int check,temp;
unsigned long i;
if(check==SUCCESS)
do
Sendbyte(0xff);
CS_0;
Sendcmd(cmd24,address,0xff);
Sendbyte(0xff);
Sendbyte(0xff);
Sendbyte(0xfe);
for(i=0;i
Sendbyte(*buffer++);
Sendbyte(0xff);
Sendbyte(0xff);
temp = Sendbyte(0xFF); //读SD卡运行响应
if((temp & 0x1F)!=0x05) //如果最后4位为0101,为操作成功。否则为操作失败。
CS_1;
return(failed); //返回错误
while ( Sendbyte(0xFF) != 0xFF);
CS_1;
return(SUCCESS); //返回成功
else
return(failed);
unsigned char buffer_data1[512];
//主函数。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
void main( void )
int q,k;
unsigned long m;
volatile unsigned char ans=0;
unsigned char write_data;
volatile unsigned long d1;
WDTCTL=WDTPW+WDTHOLD;//关狗
//P1DIR |=BIT0;
m=520;
//m=1040;
Init() ;//MSP430F149引脚初始化;
Write_One_Byte(0x14,0x01);
SD_init();
for(k=0;k<10;k++)
for(q=0,write_data=1;q<512;q++,write_data++)
buffer_data1[q]=write_data;
ans=Write_data(m*512,512,buffer_data1);
m++;
ans =Read_One_Byte(0x04);
ans =Read_One_Byte(0x05);
这就是主要程序啦~~~~斑竹帮忙看看,我已经试了很多方法,现在三星的2G卡可以写进去,但是金士顿的2G卡到了acmd41发送完一直收到0XFF,初始化不成功。。。
