proteus仿真图
这是我的proteus仿真图,设定PA0~PA6为四段数码管显示位,PA7为AD口,不显示小数点,采集电压值并显示出来,位选端口为PC0~PC4,电压源为5V,上下两电阻都为1K,利用ICCV7编译,程序如下:
//ICC-AVR application builder : 2011-8-13 下午 09:00:57
// Target : M16
// Crystal: 4.0000Mhz
#include <iom16v.h>
#include <macros.h>
#define uchar unsigned char
#define uint unsigned int
uchar const SEG7[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
uchar const ACT[4]={0xfe,0xfd,0xfb,0xf7};
uint adc_val,dis_val;
uchar i,cnt;
void port_init(void)
PORTA = 0x7F;
DDRA = 0x7F;
PORTB = 0xFF;
DDRB = 0xFF;
PORTC = 0xFF;
DDRC = 0xFF;
PORTD = 0xFF;
DDRD = 0xFF;
void adc_init(void) //模数转换初始化程序
ADCSRA=0xE3;
ADMUX=0xC7;
void timer0_init(void)//定时器0初始化子程序
TCNT0=0x83;
TCCR0=0x03;
TIMSK=0x01;
void init_devices(void)//芯片初始化程序
port_init();
timer0_init();
adc_init();
SREG=0x80;
#pragma interrupt_handler timer0_ovf_isr:10 // T/C0中断服务子函数
void timer0_ovf_isr(void)
TCNT0=0x83; //重装1ms的定时初值
cnt++; //变量cnt递增
if(++i>3)i=0;
switch(i) //根据i的值分别点亮4位数码管
case 0:PORTA=SEG7[dis_val%10];PORTC=ACT[0];break;
case 1:PORTA=SEG7[(dis_val/10)%10];PORTC=ACT[1];break;
case 2:PORTA=SEG7[(dis_val/100)%10];PORTC=ACT[2];break;
case 3:PORTA=SEG7[dis_val/1000];PORTC=ACT[3];break;
default:break;
uint ADC_Convert(void) // 模数转换
uint temp1,temp2;
temp1=(uint)ADCL;
temp2=(uint)ADCH;
temp2=(temp2<<8)+temp1;
return(temp2);
uint conv(uint i) //数据转换
long x;
long y;
x=(5000*(long)i)/1023;
y=(uint)x;
return(y);
void delay(uint K)
uint i,j;
for(i=0;i<K;i++)
for(j=0;j<140;j++);
void main(void)
init_devices(); //调用芯片初始化程序
while(1) //无限循环
if(cnt>100) //如果cnt大于100,进入if语句
adc_val=ADC_Convert(); //调用模数转换子函数得到转换值
dis_val=conv(adc_val); //将adc_avl转换成需要显示的形式
cnt=0;
delay(10);
编译结果显示如下:
C:\iccv7avr\bin\imakew -f ADZHUANHUAN.mak
iccavr -c -e -D__ICC_VERSION=722 -DATMega16 -l -g -MLongJump -MHasMul -MEnhanced ADzhuanhuan.c
iccavr -o ADZHUANHUAN -g -e:0x4000 -ucrtatmega.o -bfunc_lit:0x54.0x4000 -dram_end:0x45f -bdata:0x60.0x45f -dhwstk_size:30 -beeprom:0.512 -fihx_coff -S2 @ADZHUANHUAN.lk -lcatmega
Device 7% full.
Done. Sat Aug 13 21:02:05 2011
算是通过了吧
再在proteus中调用cof文件,运行后就像图上所示,请问为什么会不能正确显示结果呢?
本文来自电子工程师之家:http://www.eehome.cn/read.php?tid=53728
