Ubuntu10.10下不能make menuconfig问题解决
多瑙河夏之夜   2011-10-16 16:10 楼主
Ubuntu下交叉编译Linux2.6内核,输入make menuconfig发现有一些头文件找不到:
root@loong:/opt/linux-2.6.39# make menuconfig
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/docproc
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/kxgettext.o
 *** Unable to find the ncurses libraries or the
 *** required header files.
 *** 'make menuconfig' requires the ncurses libraries.
 *** Install ncurses (ncurses-devel) and try again.
make[1]: *** [scripts/kconfig/dochecklxdialog] 错误 1
make: *** [menuconfig] 错误 2
应该是编译的一些东东没装哦,要安装一下东东;
sudo apt-get install build-essential
sudo apt-get install libncurses5-dev 或者 sudo apt-get install ncurses-dev
安装完毕后就可以编译了
回复评论 (2)
你没下内核源码包吧。
http://item.taobao.com/item.htm?id=12366456386 Arduino 兼容的  maple
点赞  2011-10-16 20:31
sudo apt-get install ncurses-dev安装一下就可以
点赞  2011-10-17 13:31
    写回复
