[求助] DSP288335的IIC模块与PCF8563的通信问题
lanqinli   2011-10-17 14:24 楼主
各位大侠,偶现在用DSP28335的IIC模块与PCF8563进行通信,程序编译没有问题,我在单步运行的时候感觉不能读写PCF8563的数据,并且感觉程序进入死循环的模式了,我的IIC模块的驱动程序如下:
Uint16 I2CA_WriteData(struct I2CMSG *msg)
   Uint16 i;
   // Wait until the STP bit is cleared from any previous master communication.
   // Clearing of this bit by the module is delayed until after the SCD bit is
   // set. If this bit is not checked prior to initiating a new message, the
   // I2C could get confused.
   if (I2caRegs.I2CMDR.bit.STP == 1)
      return I2C_STP_NOT_READY_ERROR;
   // Setup slave address
   I2caRegs.I2CSAR = msg->SlaveAddress;
   // Check if bus busy
   if (I2caRegs.I2CSTR.bit.BB == 1)
      return I2C_BUS_BUSY_ERROR;
   // Setup number of bytes to send
   // MsgBuffer + Address
   I2caRegs.I2CCNT = msg->NumOfBytes+2;
   // Setup data to send
   I2caRegs.I2CDXR = msg->MemoryHighAddr;
   I2caRegs.I2CDXR = msg->MemoryLowAddr;
// for (i=0; iNumOfBytes-2; i++)
   for (i=0; iNumOfBytes; i++)
      I2caRegs.I2CDXR = *(msg->MsgBuffer+i);
   // Send start as master transmitter
   I2caRegs.I2CMDR.all = 0x6E20;
   return I2C_SUCCESS;
麻烦各位大侠帮忙看一下!谢谢了!
回复评论
暂无评论,赶紧抢沙发吧
    写回复
