msp430f149
用定时器B输出pwm,发现没有输出。然后检查控制语言:
TBCTL=TBSSEL_2+MC_1+TBCLR;
TBCCR0=19999;
TBCCR1=499+j*11.11;
P1SEL|=BIT2;
P1DIR|=BIT2;
TBCCTL1=OUTMOD_7;
发现MC_1:增计数模式,只是对TA有效。TB没有找到有关计数模式的控制语句,不知道怎么办。。。
// MSP-FET430P140 Demo - Timer_B, PWM TB1-2, Up/Down Mode, DCO SMCLK
// Description: This program generates two PWM outputs on P4.1,2 using
// Timer_B configured for up/down mode. The value in CCR0, 128, defines the
// PWM period/2 and the values in CCR1 and CCR2 the PWM duty cycles. Using
// ~800kHz SMCLK as TBCLK, the timer period is ~320us with a 75% duty cycle
// on P4.1 and 25% on P4.2.
// SMCLK = MCLK = TBCLK = default DCO ~800kHz.
// MSP430F149
// /|\| XIN|-
// --|RST XOUT|-
// | P4.1/TB1|--> CCR1 - 75% PWM
// | P4.2/TB2|--> CCR2 - 25% PWM
// M. Buccini
// Texas Instruments Inc.
// Feb 2005
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
#include
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P4DIR |= 0x06; // P4.1 and P4.2 output
P4SEL |= 0x06; // P4.2 and P4.2 TB1/2 otions
TBCCR0 = 128; // PWM Period/2
TBCCTL1 = OUTMOD_6; // CCR1 toggle/set
TBCCR1 = 32; // CCR1 PWM duty cycle
TBCCTL2 = OUTMOD_6; // CCR2 toggle/set
TBCCR2 = 96; // CCR2 PWM duty cycle
TBCTL = TBSSEL_2 + MC_3; // SMCLK, up-down mode
_BIS_SR(CPUOFF); // Enter LPM0
TI官网上的
// MSP-FET430P140 Demo - Timer_B, PWM TB1-2, Up Mode, HF XTAL ACLK
// Timer_B configured for up mode. The value in CCR0, 512-1, defines the PWM
// period and the values in CCR1 and CCR2 the PWM duty cycles. Using HF XTAL
// ACLK as TBCLK, the timer period is HF XTAL/512 with a 75% duty cycle
// ACLK = MCLK = TBCLK = HF XTAL
// //* HF XTAL REQUIRED AND NOT INSTALLED ON FET *//
// //* Min Vcc required varies with MCLK frequency - refer to datasheet *//
// MSP430F149
// /|\| XIN|-
// | | | HF XTAL (455k - 8MHz)
// --|RST XOUT|-
// M. Buccini
// Feb 2005
#include
void main(void)
volatile unsigned int i;
BCSCTL1 |= XTS; // ACLK = LFXT1 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG)); // OSCFault flag still set?
BCSCTL2 |= SELM_3; // MCLK= LFXT1 (safe)
TBCCR0 = 512-1; // PWM Period
TBCCTL1 = OUTMOD_7; // CCR1 reset/set
TBCCR1 = 384; // CCR1 PWM duty cycle
TBCCTL2 = OUTMOD_7; // CCR2 reset/set
TBCCR2 = 128; // CCR2 PWM duty cycle
TBCTL = TBSSEL_1 + MC_1; // ACLK, up mode
引用: 原帖由 永远的不知 于 2011-10-30 21:25 发表
TI官网上的
// Description: This program ge ...
LZ可以在斑斑提供的示例代码上进行修改,一般来讲这些代码是肯定可用的,可能根据IAR版本不同,头文件稍有不同
