器件型号:STM32F103VE
问题:单步调试发现没有进入中断程序,请高手指教!
代码: void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;//定义NVIC_InitTypeDef类型变量NVIC_InitStructure
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 --设置量表的基地位置在0x20000000(在RAM上)*/
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 --设置量表的基地位置在0x08000000(在FLASH上)*/
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Enable and configure IRQ channel */
NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; //中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //主优先级0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //次优先级0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //中断使能
NVIC_Init(&NVIC_InitStructure);
TestStatus CAN_Interrupt(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
CanTxMsg TxMessage;
u32 i = 0;
//u8 TransmitMailbox;
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM=DISABLE;
CAN_InitStructure.CAN_ABOM=DISABLE;
CAN_InitStructure.CAN_AWUM=DISABLE;
CAN_InitStructure.CAN_NART=DISABLE;
CAN_InitStructure.CAN_RFLM=DISABLE;
CAN_InitStructure.CAN_TXFP=DISABLE;
CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1=CAN_BS1_7tq;
CAN_InitStructure.CAN_BS2=CAN_BS2_8tq;
CAN_InitStructure.CAN_Prescaler=9;
CAN_Init(CAN1,&CAN_InitStructure);
/* CAN filter init */
// CAN_FilterInitStructure.CAN_FilterNumber=1;
// CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
// CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
// i=(0x11<<21)|(0x34<<3);
// CAN_FilterInitStructure.CAN_FilterIdHigh=(i>>16);
// CAN_FilterInitStructure.CAN_FilterIdLow=(i&0xffff);
// CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0;
// CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0;
// CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
// CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
// CAN_FilterInit(&CAN_FilterInitStructure);
CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
/* CAN FIFO0 message pending interrupt enable */
CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE);
/* initialize the value that will be returned */
ret = 0xFF;
/* transmit 1 message */
TxMessage.StdId=0x12;
TxMessage.ExtId=0x34;
TxMessage.IDE=CAN_ID_EXT;
TxMessage.RTR=CAN_RTR_DATA;
TxMessage.DLC=2;
TxMessage.Data[0]=0xDE;
TxMessage.Data[1]=0xCA;
CAN_Transmit(CAN1,&TxMessage);
/* receive message with interrupt handling */
i=0;
while((ret == 0xFF) && (i < 0xFF))
i++;
if (i == 0xFF)
ret=0;
/* disable interrupt handling */
CAN_ITConfig(CAN1,CAN_IT_FMP0, DISABLE);
return (TestStatus)ret;
void USB_LP_CAN1_RX0_IRQHandler(void)
CanRxMsg RxMessage;
RxMessage.StdId=0x00;
RxMessage.ExtId=0x00;
RxMessage.IDE=0;
RxMessage.DLC=0;
RxMessage.FMI=0;
RxMessage.Data[0]=0x00;
RxMessage.Data[1]=0x00;
CAN_Receive(CAN1,CAN_FIFO0, &RxMessage);
if((RxMessage.StdId==0x12) && (RxMessage.ExtId==0x34) && (RxMessage.IDE==CAN_ID_EXT)
&& (RxMessage.DLC==2) && ((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xDECA))
ret = 1;
else
ret = 0;
