这是库函数,因为这个错误让我找了好久。
//! Sends an address character from the specified port when operating in 9-bit
//! mode.
//! \param ulBase is the base address of the UART port.
//! \param ucAddr is the address to be transmitted.
//! This function waits until all data has been sent from the specified port
//! and then sends the given address as an address byte. It then waits until
//! the address byte has been transmitted before returning.
//! The normal data functions (UARTCharPut(), UARTCharPutNonBlocking(),
//! UARTCharGet(), and UARTCharGetNonBlocking()) are used to send and receive
//! data characters in 9-bit mode.
//! \note The availability of 9-bit mode varies with the Stellaris part in use.
//! Please consult the datasheet for the part you are using to determine
//! whether this support is available.
//! \return None.
void
UART9BitAddrSend(unsigned long ulBase, unsigned char ucAddr)
unsigned long ulLCRH;
// Check the arguments.
ASSERT(UARTBaseValid(ulBase));
// Wait until the FIFO is empty and the UART is not busy.
while(HWREG(ulBase + UART_O_FR) & (UART_FR_TXFE | UART_FR_BUSY))
// Force the address/data bit to 1 to indicate this is an address byte.
ulLCRH = HWREG(ulBase + UART_O_LCRH);
HWREG(ulBase + UART_O_LCRH) = ((ulLCRH & ~UART_LCRH_EPS) | UART_LCRH_SPS |
UART_LCRH_PEN);
// Send the address.
HWREG(ulBase + UART_O_DR) = ucAddr;
// Wait until the address has been sent.
// Restore the address/data setting.
HWREG(ulBase + UART_O_LCRH) = ulLCRH;
注意看两个while循环就知道错在哪里了。
实际运行用ROM_库也是错的!
真地么
http://shop34182318.taobao.com/
https://shop436095304.taobao.com/?spm=a230r.7195193.1997079397.37.69fe60dfT705yr
回复 沙发 ddllxxrr 的帖子
您去看看是否和我贴的一模一样,是一样的那就是错的!
回复 楼主 0nline 的帖子
有什么错误,没看出来啊。
回复 5楼 Study_Stellaris 的帖子
你看看这一句本意是判断空闲和发送缓冲器不满的,结果现在你看看现在变成了当缓冲器空或者忙的时候一直循环!
回复 6楼 0nline 的帖子
UART_FR_TXFE 为 1 ,表示 TX FIFO 为空.没有数据需要发送。为 0 ,表示有数据需要发送。
UART_FR_BUSY 为 1 ,表示 UART 正在发送数据。
当检测到 UART_FR_BUSY 为 1 时,等待应该没有错。
问题应该出在 UART_FR_TXFE 这个地方,他为 1 表示 FIFO 为空了,就不需要等待了。
为 0 的时候才需要等待。
楼主是怎么发现这个问题的?操作什么样的外设要用到这个函数呢?
回复 7楼 Study_Stellaris 的帖子
485 通讯
