stm32 新版本固件库里的 FSMC_NANDInitTypeDef结构体 为什么比旧版本的少了一项 FSMC_AddressLowMapping 那旧版本的应用程序把初始化的这一项注释掉 在新版下能正常运行吗? typedef struct { uint32_t FSMC_Bank; /*!< Specifies the NAND memory bank that will be used. This parameter can be a value of @ref FSMC_NAND_Bank */
uint32_t FSMC_Waitfeature; /*!< Enables or disables the Wait feature for the NAND Memory Bank. This parameter can be any value of @ref FSMC_Wait_feature */
uint32_t FSMC_MemoryDataWidth; /*!< Specifies the external memory device width. This parameter can be any value of @ref FSMC_Data_Width */
uint32_t FSMC_ECC; /*!< Enables or disables the ECC computation. This parameter can be any value of @ref FSMC_ECC */
uint32_t FSMC_ECCPageSize; /*!< Defines the page size for the extended ECC. This parameter can be any value of @ref FSMC_ECC_Page_Size */
uint32_t FSMC_TCLRSetupTime; /*!< Defines the number of HCLK cycles to configure the delay between CLE low and RE low. This parameter can be a value between 0 and 0xFF. */
uint32_t FSMC_TARSetupTime; /*!< Defines the number of HCLK cycles to configure the delay between ALE low and RE low. This parameter can be a number between 0x0 and 0xFF */
FSMC_NAND_PCCARDTimingInitTypeDef* FSMC_CommonSpaceTimingStruct; /*!< FSMC Common Space Timing */
FSMC_NAND_PCCARDTimingInitTypeDef* FSMC_AttributeSpaceTimingStruct; /*!< FSMC Attribute Space Timing */ }FSMC_NANDInitTypeDef;
比旧版本的少了一项 FSMC_AddressLowMapping 哪位大侠帮帮忙啊? |
stm32 新版本固件库里的
typedef struct
哪位大侠帮帮忙啊?
