[求助] MSP430169中断跑飞问题
cowboy8877   2012-4-26 08:14 楼主
这个程序运行时,在不按下按键的时候也会进入中断。不知道什么原因!求帮助!
#include
#include "delay.h"
#include "data.h"
#include "cry12864.h"
#include "d1302.h"
  #define keyin (P1IN & 0x0f)
  int  keyval=0;
  int  flag= 1;
  unsigned char w=7;
  int fen,shi,miao;
  void main(void)
  WDTCTL = WDTPW + WDTHOLD;    //关狗
  P1IES = 0x0f;    //p2.0-p2.3下降沿中断
  P1IE = 0x0f;        //打开中断使能
  P1IFG = 0x00;
  P1DIR = BIT4;//设置p2.0-p2.3为输入状态,p2.4为输出
  P1OUT = 0;
  Ini_Lcd();          //初始化液晶
  Write_Cmd(0x01);   //清屏
  Clear_GDRAM();
  Reset_DS1302();     //初始化时
  //Set_DS1302(wdata);
  _EINT();
  while(1)
    if(flag==1)
     // Write_Cmd(0x01);   //清屏
      BurstRead1302(rdata);
      fen=rdata[1]&0x0f;fen+=(rdata[1]>>4)*10;
      shi=rdata[2]&0x0f;shi+=(rdata[2]>>4)*10;
      miao=rdata[0]&0x0f;miao+=(rdata[0]>>4)*10;
      shu(0,7,shi,2);                 //显示小时
      shu(0,10,fen,2);               //显示分钟
      shu(0,13,miao,2);                //显示分钟
      //zifu(0,9,2,1);
     // shu(0,7,shi,2);
      else
#pragma vector = PORT1_VECTOR
__interrupt void PORT1_ISR(void)
  switch(P1IFG)
      case 0x01:
                            if(keyin == 0x0e)
                              delay_ms(12);
                              if(keyin == 0x0e)
                                while(keyin != 0x0f);
                                flag=0;
                                DrowAnywhere(w*8,0,8,16,fanhei);
                                if(w<12)
                                  w=w+0x03;
                                else
                                  w=7;
                                DrowAnywhere(w*8,0,8,16,fanbai);
                                P1IFG = 0x00;
       case 0x02:
                            if(keyin == 0x0d)
                              delay_ms(12);
                              if(keyin == 0x0d)
                                if(w==7)
                                    shi++;
                                     if(shi == 24)
                                         shi = 0;
                                     shu(0,7,shi,2);
                               if(w==10)
                                     fen++;
                                     if(fen == 60)
                                          fen = 0;
                                     shu(0,10,fen,2);
                               else
                                     miao++;
                                     if(miao == 60)
                                          miao = 0;
                                     shu(0,10,miao,2);
                               P1IFG = 0x00;
        case 0x04:
                            if(keyin == 0x0b)
                              delay_ms(12);
                              if(keyin == 0x0b)
                                 if(w==7)
                                     shi--;
                                     if(shi < 0)
                                         shi = 23;
                                     shu(0,7,shi,2);
                                 if(w==10)
                                     fen--;
                                     if(fen < 0)
                                          fen = 59;
                                     shu(0,10,fen,2);
                               else
                                        miao--;
                                     if(miao < 0)
                                          miao = 59;
                                     shu(0,10,miao,2);
                                P1IFG = 0x00;
      case 0x08:
                         if(keyin == 0x07)
                              delay_ms(12);
                              if(keyin == 0x07)
                                 wdata[0] = 0x00;
                                 wdata[1] = (fen%10)&0x0f;wdata[1] += (fen/10)<<4;
                                 wdata[2] = (shi%10)&0x0f;wdata[2] += (shi/10)<<4;
                                 Set_DS1302(wdata);
                                 flag = 1;
                              P1IFG = 0x00;
                          break;
                          default:
                            P1IFG = 0x00;
                            break;
回复评论 (2)
不悬赏怎么看这么长的程序呀
没工作,没女人老婆,没宽带 ,  没钱
点赞  2012-4-26 17:16
首先确认一下你的硬件是否正确,在按键输入的时候,在芯片上的管脚电平状态
点赞  2012-4-28 16:28
    写回复
