下面贴个源码,一起学习
// MSP430G2x33/G2x53 Demo - ADC10, DTC Sample A10 32x, 1.5V, Repeat Single, DCO
// Description: Use DTC to sample A10 32 times with reference to internal 1.5v.
// Vref Software writes to ADC10SC to trigger sample burst. In Mainloop MSP430
// waits in LPM0 to save power until ADC10 conversion complete, ADC10_ISR(DTC)
// will force exit from any LPMx in Mainloop on reti. (ADC10OSC/4)/64
// determines sample time which needs to be greater than 30us for temperature
// sensor. DTC transfers conversion code to RAM 200h - 240h. P1.0 set at start
// of conversion burst, reset oncompletion. Temperature sensor offset and slope
// will vary from device to device per datasheet tolerance.
// /|\| XIN|-
// --|RST XOUT|-
// A7 P1.0|-->LED
// D. Dang
// Texas Instruments Inc.
// December 2010
// Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include "msp430g2553.h"
unsigned short tempdata[32];
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
ADC10CTL1 = INCH_7 + ADC10DIV_3 + CONSEQ_2;
ADC10CTL0 = SREF_1 + ADC10SHT_3 + MSC + REFON + ADC10ON + ADC10IE+REF2_5V;
ADC10AE0 = 0x80; // A7
__enable_interrupt(); // Enable interrupts.
TACCR0 = 30; // Delay to allow Ref to settle
TACCTL0 |= CCIE; // Compare-mode interrupt.
TACTL = TASSEL_2 + MC_1; // TACLK = SMCLK, Up mode.
LPM0; // Wait for delay.
TACCTL0 &= ~CCIE; // Disable timer Interrupt
__disable_interrupt();
ADC10DTC1 = 0x20; // 32 conversions
P1DIR |= 0x01; // Set P1.0 output
for (;;)
ADC10CTL0 &= ~ENC; //Sampling and conversion stop
while (ADC10CTL1 & BUSY); // Wait if ADC10 core is active
ADC10SA = (unsigned short)tempdata; // Data buffer start
ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
__bis_SR_register(CPUOFF + GIE); // LPM0, ADC10_ISR will force exit
if(tempdata[0]>0x1ff)
P1OUT |= 0x01;
else P1OUT &= ~0x01;
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
__bic_SR_register_on_exit(CPUOFF); // Clear CPUOFF bit from 0(SR)
#pragma vector=TIMER0_A0_VECTOR
__interrupt void ta0_isr(void)
TACTL = 0;
LPM0_EXIT; // Exit LPM0 on return
