【课后练习】LaunchPad课后练习六之LCD12864显示图片
1. 原理图
2. 取模过程
当然你也可以不保存单色位图,把图片导入word,选择黑白,如下:
打开制作好的图片:
取模方式
3. 实验现象
**** LAUNCH PAD 学习之LCD ***
**** MCU: MSP430 ***
**** 作者: 常见泽 ***
**** 2012.05.30.11:16 ***
**** 实验现象:LCD显示EE LOG ***
****P1.0~P1.7 数据口 P2.0 P2.1 P2.2 en rs Psb***
#include <msp430g2452.h>
#define uchar unsigned char
#define uint unsigned int
unsigned char table[]="EE-LaunchPad";
unsigned char num;
void delay_1ms(void)
unsigned int i;
for (i=0;i<1140;i++);
const unsigned char ucpic[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0F,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0xFF,0xC3,0xFC,0x00,0x30,0x00,0x06,0x00,0xE0,0x06,0x66,0x19,0x8C,0x31,
0x00,0x3F,0xFE,0x01,0xFE,0x02,0x39,0x00,0x06,0x00,0xC0,0x0C,0x62,0x19,0x8C,0x31,
0x00,0x3F,0xF8,0x00,0xFE,0x07,0x31,0x80,0xFC,0x00,0xC0,0x0C,0x62,0x19,0x8C,0x31,
0x00,0x3F,0xF0,0x00,0xFE,0x06,0x31,0x80,0x78,0x00,0xC0,0x0C,0x66,0x1D,0xDC,0x31,
0x00,0x3F,0xE0,0x01,0xFE,0x06,0x31,0x80,0x30,0x00,0xC0,0x0C,0x00,0x19,0xCC,0x30,
0x00,0x3F,0xC0,0x03,0xFE,0x07,0x39,0x80,0x38,0x00,0xC0,0x1F,0x00,0x18,0x8C,0x00,
0x00,0x3F,0xC0,0x3F,0xFE,0x06,0x31,0x80,0x38,0x00,0xC0,0x3D,0x18,0x19,0x8C,0x0C,
0x00,0x3F,0x80,0x7F,0xFE,0x06,0x31,0x80,0x38,0x00,0xE0,0x3D,0x18,0x19,0x8C,0x1C,
0x00,0x3F,0x80,0xFF,0xFE,0x06,0x31,0x80,0x18,0x00,0xE0,0x3D,0x18,0x19,0x8C,0x3C,
0x00,0x3F,0x81,0xF3,0xFE,0x07,0x31,0x80,0x38,0x00,0xE0,0x3F,0x18,0x19,0xD8,0x0C,
0x00,0x3F,0x03,0xC1,0xFE,0x00,0x30,0x00,0x30,0x00,0xE0,0x3F,0x18,0x18,0x00,0x0C,
0x00,0x3F,0x03,0xC0,0xFE,0x00,0x30,0x01,0xF0,0x00,0xE0,0x35,0x18,0x1C,0x00,0x0C,
0x00,0x3F,0x03,0x80,0xFE,0x00,0x3C,0x80,0x00,0x00,0xE0,0x0C,0x18,0x0C,0x00,0x18,
0x00,0x3F,0x03,0x80,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0x03,0xC0,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0x01,0xC1,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x00,0x3F,0x81,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0x80,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0x80,0x7F,0xFE,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x00,0x00,0x00,0x00,
0x00,0x3F,0xC0,0x0F,0xFE,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,
0x00,0x3F,0xE0,0x01,0xFE,0x01,0x01,0x80,0x00,0x60,0x10,0xD0,0x00,0x00,0x00,0x00,
0x00,0x3F,0xF0,0x01,0xFE,0x04,0x44,0x4C,0x89,0xB1,0x93,0x70,0x00,0x00,0x00,0x00,
0x00,0x3F,0xF8,0x00,0xFE,0x0C,0x4C,0x4D,0xD3,0x1B,0x12,0x30,0x78,0xE3,0xF8,0x3C,
0x00,0x3F,0xFC,0x01,0xFE,0x0F,0xCF,0xC5,0xF2,0x12,0x24,0x30,0x81,0x16,0x48,0x60,
0x00,0x3F,0xFF,0x01,0xFE,0x08,0x08,0x06,0x62,0x12,0x24,0x20,0x82,0x14,0x88,0x40,
0x00,0x3F,0xFF,0xFF,0xFE,0x08,0x08,0x06,0x63,0x26,0x26,0x60,0x83,0x24,0x88,0x40,
0x00,0x0F,0xFF,0xFF,0xFE,0x07,0x07,0x04,0x41,0xC4,0x63,0xE4,0x71,0xC0,0x92,0x39,
0x00,0x07,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
}; //图像数据
* N ms延时函数
void delay_nms(unsigned int n)
unsigned int i=0;
for (i=0;i<n;i++)
delay_1ms();
void write_com(unsigned int com)
//lcdrs = 0;
P2OUT&= 0xfd;
P1OUT = com;
delay_nms(5);
//lcden = 1;
P2OUT|= 0x01;
delay_nms(5);
P2OUT&= 0xfe;
void write_dat(unsigned int dat)
//lcdrs = 1;
P2OUT |= 0x02;
P1OUT = dat;
delay_nms(5);
//lcden=1;
P2OUT|= 0x01;
delay_nms(5);
// lcden=0;
P2OUT&= 0xfe;
void disp_12864(uchar addr,const uchar *pt,uchar num)
uchar i;
write_com(addr);
for(i=0;i<(num*2);i++)
write_dat(*(pt++));
void init()
//PSB=1;//并口模式
P2OUT |= BIT2;
delay_nms(15);
//EN=0;
P2OUT&= 0xfe;
delay_nms(5);
write_com(0x30);
delay_nms(1);
write_com(0x08);//清屏
delay_nms(1);
write_com(0x0c);//开显示,关光标
delay_nms(1);
write_com(0x01);
delay_nms(1);
write_com(0x06);//第一行显示位置
delay_nms(1);
void lcd12864_image(const unsigned char *p)
int x,y;
write_com(0x34); //扩展指令集动作,绘图显示OFF
for (y=0;y<32;y++) //送上半屏显示数据
write_com(0x80|y); //送显示Y坐标0x80-0x9f
write_com(0x80); //送显示X坐标0x80
for (x=0;x<16;x++)
write_dat(*p);
p++;
for (y=0;y<32;y++) //送下半屏显示数据
write_com(0x88); //送显示X坐标0x88
for (x=0;x<16;x++)
write_dat(*p);
p++;
write_com(0x36); //扩展指令集动作,绘图显示ON
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR |= 0xff; // P1.2 output
P2DIR |= 0xff;
init();
write_com(0x01); //清除显示(清零DDRAM)
lcd12864_image(ucpic); //送图像显示数据
delay_nms(5000);
while(1);
回复 板凳 lxttian 的帖子
多谢支持啊 多谢
回复 5楼 yzl624358 的帖子
x谢谢支持 谢谢
回复 沙发 常见泽1 的帖子
unsigned char table[]=\"EE-LaunchPad\";数组这样定义会报错啊
回复 7楼 tanfeng193 的帖子
把斜杠去掉 这个代码输入的格式 有问题 我复制进去的是没有斜杠的
unsigned char table[]="EE-LaunchPad"; 我输入的是这个 但是用代码格式输入会出现那个斜杠
学弟一直没看懂~
请问 程序中的
uchar i;
write_com(addr);
write_dat(*(pt++));
这个子程序是什么作用啊?
放这么大的一个数组,IAR编译器会说堆栈溢出怎么办?
回复 10楼 暴风雪282 的帖子
我的木有提示 溢出 你用的2231?
不好意思啊,看不到我的消息回复...我用的是2553啊,还是放不下,说是要压缩.
其实可以使用网页版ps,调整一下阈值,可以获得更好的取模效果
