STM32F051来了……
Blwk-lps   2012-6-8 10:57 楼主
■ Operating conditions:
– Voltage range: 2.0 V to 3.6 V
■ ARM 32-bit Cortex®-M0 CPU (48 MHz max)
■ Memories
– 16 to 64 Kbytes of Flash memory
– 8 Kbytes of SRAM with HW parity checking
■ CRC calculation unit
■ Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
■ Calendar RTC with alarm and periodic wakeup
from Stop/Standby
■ Reset and supply management
– Power-on/Power down reset (POR/PDR)
– Programmable voltage detector (PVD)
■ Low power Sleep, Stop, and Standby modes
■ VBAT supply for RTC and backup registers
■ 5-channel DMA controller
■ 1 × 12-bit, 1.0 μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6V
– Separate analog supply from 2.4 up to 3.6
■ Two fast low-power analog comparators with
programmable input and output
■ One 12-bit D/A converter
■ Up to 55 fast I/Os
– All mappable on external interrupt vectors
– Up to 36 I/Os with 5 V tolerant capability
■ Up to 18 capacitive sensing channels
supporting touchkey, linear and rotary touch
sensors
■ 96-bit unique ID
■ Serial wire debug (SWD)
■ Up to 11 timers
– One 16-bit 7-channel advanced-control
timer for 6 channels PWM output, with
deadtime generation and emergency stop
– One 32-bit and one 16-bit timer, with up to
4 IC/OC, usable for IR control decoding
– One 16-bit timer, with 2 IC/OC, 1 OCN,
– Two 16-bit timers, each with IC/OC and
OCN, deadtime generation, emergency
stop and modulator gate for IR control
– One 16-bit timer with 1 IC/OC
– Independent and system watchdog timers
– SysTick timer: 24-bit downcounter
– One 16-bit basic timer to drive the DAC
■ Communication interfaces
– Up to two I2C interfaces; one supporting
Fast Mode Plus (1 Mbit/s) with 20 mA
current sink, SMBus/PMBus, and wakeup
from STOP
– Up to two USARTs supporting master
synchronous SPI and modem control; one
with ISO7816 interface, LIN, IrDA
capability, auto baud rate detection and
wakeup feature
– Up to two SPIs (18 Mbit/s) with 4 to 16
programmable bit frame, 1 with I2S
interface multiplexed
– HDMI CEC interface, wakeup on header
reception
Table 1. Device summary
Reference Part number
STM32F051x4 STM32F051K4, STM32F051C4, STM32F051R4
STM32F051x6 STM32F051K6, STM32F051C6, STM32F051R6
STM32F051x8 STM32F051C8, STM32F051R8, STM32F051K8
回复评论
暂无评论,赶紧抢沙发吧
    写回复
