#include <intrins.h>
#include <reg52.h> //52系列单片机头文件
#define uchar unsigned char
#define uint unsigned int
#define RdCommand 0x01 //定义ISP的操作命令
#define PrgCommand 0x02
#define EraseCommand 0x03
#define Error 1
#define Ok 0
#define WaitTime 0x01 //定义CPU的等待时间
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar num;
sfr ISP_DATA=0xe2; //寄存器申明
sfr ISP_ADDRH=0xe3;
sfr ISP_ADDRL=0xe4;
sfr ISP_CMD=0xe5;
sfr ISP_TRIG=0xe6;
sfr ISP_CONTR=0xe7;
sbit dula=P2^6; //申明U1锁存器的锁存端
sbit wela=P2^7; //申明U2锁存器的锁存端
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--) //i=xms即延时约xms毫秒
for(j=110;j>0;j--);
void display(uchar shi,uchar ge) //显示子函数
dula=1;
P0=table[shi]; //送十位段选数据
dula=0;
P0=0xff; //送位选数据前关闭所有显示,防止打开位选锁存时
wela=1; //原来段选数据通过位选锁存器造成混乱
P0=0xfe; //送位选数据
wela=0;
delayms(5); //延时
dula=1;
P0=table[ge]; //送个位段选数据
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delayms(5);
void ISP_IAP_enable(void) /* ================ 打开 ISP,IAP 功能 ================= */
EA = 0; /* 关中断 */
ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
ISP_CONTR = ISP_CONTR | WaitTime; /* 写入硬件延时 */
ISP_CONTR = ISP_CONTR | 0x80; /* ISPEN=1 */
void ISP_IAP_disable(void) /* =============== 关闭 ISP,IAP 功能 ================== */
ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
ISP_TRIG = 0x00;
EA = 1; /* 开中断 */
void ISPgoon(void) /* ================ 公用的触发代码 ==================== */
ISP_IAP_enable(); /* 打开 ISP,IAP 功能 */
ISP_TRIG = 0x5a; /* 触发ISP_IAP命令字节1 */
ISP_TRIG = 0xA5; /* 触发ISP_IAP命令字节2 */
_nop_();
unsigned char byte_read(unsigned int byte_addr) /* ========= 字节读 ============= */
ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* 地址赋值 */
ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
ISP_CMD = ISP_CMD & 0xf8; /* 清除低3位 */
ISP_CMD = ISP_CMD | RdCommand; /* 写入读命令 */
ISPgoon(); /* 触发执行 */
ISP_IAP_disable(); /* 关闭ISP,IAP功能 */
return (ISP_DATA); /* 返回读到的数据 */
void SectorErase(unsigned int sector_addr) /* =========== 扇区擦除 ============ */
unsigned int iSectorAddr;
iSectorAddr = (sector_addr & 0xfe00); /* 取扇区地址 */
ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
ISP_ADDRL = 0x00;
ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 */
ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 */
void byte_write(unsigned int byte_addr, unsigned char original_data) /* ==== 字节写 ==== */
ISP_ADDRH = (unsigned char)(byte_addr >> 8); /* 取地址 */
ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 */
ISP_CMD = ISP_CMD | PrgCommand; /* 写命令2 */
ISP_DATA = original_data; /* 写入数据准备 */
ISP_IAP_disable(); /* 关闭IAP功能 */
void main()
uchar a,b,num1;
TMOD=0x01; //设置定时器0为工作方式1(0000 0001)
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
num1=byte_read(0x0000);//程序开始时读取EEPROM中数据
if(num1>=60) //防止首次上电时读取出错
num1=0;
while(1)
if(num>=20)
num=0;
num1++;
SectorErase(0x0000);//擦除扇区
byte_write(0x0000,num1);//重新写入数据
if(num1==60)
num1=0;
a=num1/10;
b=num1%10;
display(a,b);
void timer0() interrupt 1
num++;
