2.you are communicating with an external device over an I
LDR R10,=0x40301688
@read from register 02 from the I
MOV R0,#0X80 @slave adress in the I
STR R0,[R10]
MOV R0,#0x69 @set byte to start a read after write cycle
STR R0,[R10,#0x8]
BL POLLTB
MOV R0,#0X02 @要读入器件内部地址02单元
STR R0,[R10]
MOV R0,#0X68
STR R0,[R10,#0X8]
BL POLLTB
MOV R0,#0X81 @设置读入周期@
STR R0,[R10]
MOV R0,#0x69 @START=1,STOP=0,TB=1@
STR R0,[R10,#0x8]
BL POLLTB
MOV R0,#0X
STR R0,[R10,#0X8] @设置开始读入@
BL POLLTB @等待读入结束
LDR R1,[R10]
MOV R2,#0X80
ORR R1,R1,R2
MOV R0,#0X80
STR R0,[R10]
MOV R0,#0x69
STR R0,[R10,#0x8]
BL POLLTB@
MOV R0,#0X02 @写入器件内部地址02单元
STR R0,[R10]
MOV R0,#0X68
STR R0,[R10,#0X8]
BL POLLTB
MOV R0,R1 @这是写入器件02单元的数据@
STR R0,[R10]
MOV R0,#0X
STR R0,[R10,#0X8]
BL POLLTB @等响应
3.briefly describe the operation of a Successive Approximation type A/D converter and in general terms compare its speed with that of the other types of converters( flash , dual slope, sigma-delta)
4.describe why a low-pass filter is often put in series with the input of an A/D converter that is to be used to digitize rapidly changing signals such as audio frequency sinewave signals.
5.describe the meaning of five of the following terms.
a. CRC
b. half-duplex
c. snubber circuit
d. Quantization Error
e. sigma-delta A/D converter
