已知BUG:显示”液晶12864驱动程序“乱码,就是中文和西文必须分开显示
代码:
主函数main.c
#include <msp430g2553.h>
#include "lcd12864.h"
void main()
WDTCTL = WDTPW + WDTHOLD;
BCSCTL1 = CALBC1_8MHZ; // 多谐2楼指导
DCOCTL = CALDCO_8MHZ;
P1DIR|=0xff;
P2DIR|=0xff;
lcdreset(); //初始化LCD12864屏
clrscreen();
write_com(0x80); //位置控制
printstring("液晶12864");
write_com(0x90); //位置控制
write_swcom(0x8a);//写单个数控制字
write_swdat(0x35);
write_swdat(0x36);
write_com(0x95); //位置控制
write_swdat(0x38);
write_com(0x88); //位置控制
while(1);
12864.c
#include <msp430g2553.h> //包含库文件
#define uint unsigned int
#define uchar unsigned char
uchar LCD_table1[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};//0123456789
//sbit LCD_RS = P2.0;
//sbit LCD_RW = P2.1;
//sbit LCD_EN = P2.2;
//sbit LCD_PSB= P2.3;
//sbit LCD_RST= P2.4;
#define LCD_DataIn P1DIR=0x00;//数据口方向设置为输入
#define LCD_DataOut P1DIR=0xff;//数据口方向为输出
#define LCD2MCU_Data P1IN
#define MCU2LCD_Data P1OUT
#define LCD_RS_L P2OUT&=0xfe;
#define LCD_RS_H P2OUT|=0x01;
#define LCD_RW_L P2OUT&=0xfd;
#define LCD_RW_H P2OUT|=0x02;
#define LCD_EN_L P2OUT&=0xfb;
#define LCD_EN_H P2OUT|=0x04;
#define LCD_PSB_L P2OUT&=0xf7;
#define LCD_PSB_H P2OUT|=0x08;
#define LCD_RST_L P2OUT&=0xef;
#define LCD_RST_H P2OUT|=0x10;
void delay_1ms()
uint i;
for(i=0;i<1140;i++);
void delay_nms(uint n)
uint j;
for(j=0;j<n;j++)
delay_1ms();
/*------------------检查忙位-----------------------------*/
void chk_busy()
uchar lcdtemp=0;
LCD_RS_L;
LCD_RW_H;
LCD_DataIn;
do
LCD_EN_H;
_NOP();
lcdtemp = LCD2MCU_Data;
LCD_EN_L;
while(lcdtemp&0x80);
LCD_DataOut;
/*------------------写命令到LCD------------------------------*/
void write_com(uchar cmdcode)
chk_busy();
LCD_RW_L;
MCU2LCD_Data = cmdcode;
LCD_EN_H;
_NOP();
LCD_EN_L;
/*-------------------写数据到LCD----------------------------*/
void write_data(uchar Dispdata)
chk_busy();
LCD_RS_H;
LCD_RW_L;
MCU2LCD_Data = Dispdata;
LCD_EN_H;
_NOP();
LCD_EN_L;
/*------------------初始化LCD屏--------------------------*/
void lcdreset()
LCD_RST_L;
delay_nms(60);
LCD_RST_H;
delay_nms(1);
LCD_PSB_H;
delay_nms(600);
write_com(0x30);
delay_nms(10); //选择基本指令集
write_com(0x02); //地址归位
delay_nms(5);
write_com(0x0c); //开显示(无游标、不反白)
delay_nms(10);
write_com(0x01); //清除显示,并且设定地址指针为00H
delay_nms(500);
write_com(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
delay_nms(10);
/*------------------显示字符串--------------------------*/
void printstring(uchar *s)
while(*s>0)
write_data(*s);
s++;
delay_nms(5);
/*------------------清屏命令--------------------------*/
void clrscreen()
write_com(0x01);
delay_nms(10);
void write_swcom(uchar com)
LCD_RS_L;
LCD_RW_L;
delay_nms(1);
MCU2LCD_Data=com;
LCD_EN_L;
delay_nms(1);
void write_swdat(uchar dat)
chk_busy();
LCD_RS_H;
LCD_RW_L;
delay_nms(1);
MCU2LCD_Data=dat;
LCD_EN_H;
delay_nms(1);
LCD_EN_L;
delay_nms(1);
12864.h
#ifndef LCD12864_H_
#define LCD12864_H_
extern void delay_1ms();
extern void delay_nms(uint n);
extern void chk_busy();
extern void write_com(uchar cmdcode);
extern void write_data(uchar Dispdata);
extern void lcdreset();
extern void printstring(uchar *s);
extern void clrscreen();
extern void write_swcom(uchar com);
extern void write_swdat(uchar dat);
#endif /* LCD12864_H_ */
