[讨论] TFT 驱动的移植
dafs12   2012-7-19 19:22 楼主
#include "tft_driver.h"
void delay_SYS(unsigned int count)
        for(count=0;count<200;count++);
select_16bit_reg(unsigned char reg)                   //select the register
        RS_L;        //À­¸ßRS
        CS_L;                                                            //À­µÍCS
        DATA_PORT = (unsigned char)0x00;         //¸ß8λµØÖ·
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        GPIOPinWrite(LCD_IE_BASE ,LCD_IE_PIN,LCD_IE_PIN);
        DATA_PORT =(unsigned char)reg;                   //µÍ8λµØÖ·
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        CS_H;        //À­¸ßCS
        GPIOPinWrite(LCD_IE_BASE ,LCD_IE_PIN,0X00);
write_16bit_data(unsigned char adata)                //write data to register
        //unsigned int temp;
        CS_L;        //À­µÍCS
        RS_H;        //À­¸ßRS
        //temp =adata;
        DATA_PORT =(unsigned char)(adata>>8);
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        DATA_PORT =(unsigned char)adata;
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        CS_H;        //À­¸ßCS
void write_to_reg(unsigned short adata,unsigned short reg)
        /*select_16bit_reg(reg);                           //select the register
        write_16bit_data(data);                                //write data to register*/
//        unsigned int temp;
        RS_L;        //À­¸ßRS
        CS_L;                                                            //À­µÍCS
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        CS_H;        //À­¸ßCS
        GPIOPinWrite(LCD_IE_BASE ,LCD_IE_PIN,0);
        CS_L;        //À­µÍCS
        RS_H;        //À­¸ßRS
//        temp =adata;
        WR_L;        //À­µÍWR
        WR_H;
        GPIOPinWrite(LCD_IE_BASE ,LCD_IE_PIN,LCD_IE_PIN);        //À­¸ßWR
        WR_L;        //À­µÍWR
        WR_H;        //À­¸ßWR
        CS_H;        //À­¸ßCS
void initial_lcd()
        SysCtlPeriEnable(LCD_PERIPH);                                       /* ʹÄÜÏàÓ¦µÄGPIO               */
    GPIOPinTypeOut(LCD_CS_BASE_PIN);                                    /* ÉèÖÃÏàÓ¦µÄ¿ØÖƹܽÅΪÊä³ö     */
    GPIOPinTypeOut(LCD_WR_BASE_PIN);                                    /* ÉèÖÃÏàÓ¦µÄ¿ØÖƹܽÅΪÊä³ö     */
    GPIOPinTypeOut(LCD_RS_BASE_PIN);                                    /* ÉèÖÃÏàÓ¦µÄ¿ØÖƹܽÅΪÊä³ö     */
    GPIOPinTypeOut(LCD_RD_BASE_PIN);                                    /* ÉèÖÃÏàÓ¦µÄ¿ØÖƹܽÅΪÊä³ö     */
    GPIOPinTypeOut(LCD_RST_BASE_PIN);
        GPIOPinTypeOut(LCD_IE_BASE_PIN);                                  /* ÉèÖÃÏàÓ¦µÄ¿ØÖƹܽÅΪÊä³ö     */
    GPIOPinTypeOut(DATA_PORT_BASE_PIN);                                 /* ÉèÖÃÏàÓ¦µÄÊý¾Ý¹Ü½ÅΪÊä³ö     */
        CS_H;        //³õʼ»¯CSΪ¸ß        //³õʼ»¯RDΪ¸ß
        RST_H;        //³õʼ»¯RSTΪ¸ß
        delay_SYS(10);        //³õʼ»¯Êý¾Ý¶Ë¿ÚΪ¸ß
        RST_L;        //À­µÍ¸´Î»¹Ü½Å
        delay_SYS(10);
        RST_H;        //À­¸ß¸´Î»¹Ü½Å
        delay_SYS(50);
        //write_to_reg(unsigned int data,unsigned int reg)
        write_to_reg(0x0001,0x0100);                //selet oscillation control register R00
                                //start oscillation;wait for 10ms at least
        //-----------------------------------------------------------------        //Power Control 1
        write_to_reg(0x0002,0x0700);
        write_to_reg(0x0003,0x1018);
        write_to_reg(0x0004,0x0000);
        write_to_reg(0x0008,0x0202);
        write_to_reg(0x0009,0x0000);
        write_to_reg(0x000A,0x0000);
        write_to_reg(0x000C,0x0000);
        write_to_reg(0x000d,0x0000);
        write_to_reg(0x000f,0x0000);
        for(i=50000;i>0;i--);
                LCD_WriteReg(0x07,0x0101);
        write_to_reg(0x0010,0x0000);
        write_to_reg(0x0011,0x0007);
        write_to_reg(0x0012,0x0000);
        write_to_reg(0x13,0x0000);
        write_to_reg(0x29,0x0018);
        write_to_reg(0x2b,0x000d);
        //*SS = 1,the BGR shauld be 1;528 * 216 dot
/*        write_to_reg(0x30,0x0004);                 //LCD wave form Control R02
        delay_SYS(2);                                                //3 filds
        //write_to_reg(0x1230,0x0003);
        write_to_reg(0x0031,0x0307);             //Entry Mode Register
        write_to_reg(0x0032,0x0002);        //BGR = 1;ʹÓøßËÙģʽд GRAM;
        write_to_reg(0x0035,0x0206);        //I/D1-0=11:µØÖ·×Ô¶¯¼Ó1;AM=0:µØÖ·¸üÐÂΪˮƽ·½Ïò;LG2-0=0
        write_to_reg(0x0036,0x0408);
        write_to_reg(0x0037,0x0507);                //Compare Register 1
        write_to_reg(0x0038,0x0204);                 //Compare Register 2
        //select_16bit_reg(0x0006);                   //reserved and disable
        write_to_reg(0x0039,0x0707);                //Display Control 1
        delay_SYS(2);                                                //Õý³£ÏÔʾ£»½ûÖ¹Òº¾§·ÖÆÁÏÔʾ¹¦ÄÜ,D1-0=11
        write_to_reg(0x003C,0x0405);                  //Display Control 2
        //Ç°ºó²»ÏÔʾµÄ¹âÕ¤À¸¾ùΪ8
        write_to_reg(0x003D,0x0F02);                 //Display Control 3
        //ÆÕͨ·½Ê½É¨Ãè²»ÏÔʾÇøÓò£»É¨ÃèƵÂÊ
         delay_SYS(150);
        //select_16bit_reg(0x000a);  */                 //reserved and disable
        write_to_reg(0x0050,0);
        write_to_reg(0x0051,239);
        write_to_reg(0x0052,0x0000);
        write_to_reg(0x0053,319);
        write_to_reg(0x0060,0x2700);
        write_to_reg(0x0061,0x0001);
        write_to_reg(0x006a,0x0000);
        write_to_reg(0x0080,0x0000);
    write_to_reg(0x0081,0x0000);
    write_to_reg(0x0082,0x0000);
    write_to_reg(0x0083,0x0000);
    write_to_reg(0x0084,0x0000);
    write_to_reg(0x0085,0x0000);
        write_to_reg(0x0090,(0<<7)|(16<<0));
        //select_16bit_reg(0x0032);
        write_to_reg(0x0092,0x0000);
              write_to_reg(0x0093,0x0001);
        write_to_reg(0x0095,0x0110);
        write_to_reg(0x0097,(0<<8));
        write_to_reg(0x0098,0x0000);
        write_to_reg(0x0007,0x0173);
我用的lm3s2965想移植驱动为ili9320的TFT初始化程序,
上面是我的移植的驱动程序;请高手帮我看哈对不,还有以张TFT的原理图;
回复评论
暂无评论,赶紧抢沙发吧
    写回复
