[求助] 求助关于G2内部I2C程序问题
465055608   2012-7-21 17:28 楼主
#include "msp430g2553.h"
unsigned int RxByteCtr;
unsigned int RxWord;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR |= BIT0;                            // P1.0 output
  P1SEL |= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  P1SEL2|= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset                I2C复位
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode   主设备选择UCMST+I2C UCMODE_3+同步模式UCSYNC
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset       SMCLK+I2C复位
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz      波特率控制 100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x4e;                         // Set slave address              从设备地址
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation复位使能禁止
  IE2 |= UCB0RXIE;                          // Enable RX interrupt              接收中断使能
  TACTL = TASSEL_2 + MC_2;                  // SMCLK, contmode
  while (1)
    RxByteCtr = 2;                          // Load RX byte counter
    UCB0CTL1 |= UCTXSTT;                    // I2C start condition              产生START条件
    __bis_SR_register(CPUOFF + GIE);        // Enter LPM0, enable interrupts    进入低功耗模式,打开全局中断
                                            // Remain in LPM0 until all data
                                            // is RX'd
    if (RxWord < 0x1d00)                    // >28C?
      P1OUT &= ~0x01;                       // No, P1.0 = 0
    else
      P1OUT |= 0x01;                        // Yes, P1.0 = 1
    __disable_interrupt();
    TACCTL0 |= CCIE;                        // TACCR0 interrupt enabled
                                            // Remain in LPM0 until TACCR0
                                            // interrupt occurs
    TACCTL0 &= ~CCIE;                       // TACCR0 interrupt disabled
#pragma vector = TIMER0_A0_VECTOR
__interrupt void TA0_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Exit LPM0                退出低功耗模式
// The USCIAB0TX_ISR is structured such that it can be used to receive any
// 2+ number of bytes by pre-loading RxByteCtr with the byte count.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
  RxByteCtr--;                              // Decrement RX byte counter
  if (RxByteCtr)
    RxWord = (unsigned int)UCB0RXBUF << 8;  // Get received byte
    if (RxByteCtr == 1)                     // Only one byte left?
      UCB0CTL1 |= UCTXSTP;                  // Generate I2C stop condition
  else
    RxWord |= UCB0RXBUF;                    // Get final received byte,
                                            // Combine MSB and LSB
这是例程1的程序,其中有点不明白,他用定时器0在干吗,有什么作用吗,还有,在while(1)里面,把CCIE开启是干嘛的?他设置了模式2,这个到了0xffff中断就可以了,为什么还要设置CCIE?
回复评论 (1)
其中那个定时器的作用明白了,是用来唤醒CPU的,但是新的问题又出来了,那个TMP100通过I2C是一直在传输温度值还是说中间有个间隔的定值。以及那个二次读取温度中断的话,会是2次的温度值相加,这样必然大于0x1d00,那这样判断是否大于28℃还有什么意义?
点赞  2012-7-21 17:45
    写回复
